08-14-2020, 03:14 PM | #1 |
brake squeak
My recently restored 36 has a single wheel squeak when the brake is applied, but only the last 10-20 feet before a completed stop. I have driven 100 miles on the new shoes and no change. Any ideas? Thanks Bruce
08-14-2020, 04:40 PM | #2 |
Re: brake squeak
sounds like a little oil/grease is on the lining. try spraying brake cleaner on the shoes--hard to do but try
08-15-2020, 07:41 PM | #3 |
Re: brake squeak
I'd keep driving it. Are the shoes chamferred on the leading/trailing edges??
Paul in CT |
08-15-2020, 09:03 PM | #4 |
Re: brake squeak
ditto on chamferring the egdes
08-16-2020, 07:21 AM | #5 |
Re: brake squeak
Squeaks are usually from the metal to metal parts. My dad has a squeak in his Model a and I lubricated all the rollers pins and what not and that pretty much cleared it up. Used permatex brake grease.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
08-16-2020, 10:36 PM | #6 |
Re: brake squeak
08-16-2020, 11:38 PM | #7 |
Re: brake squeak
While chamferring, lightly run some 600 grit over the shoes and brake drum to remove any junk that may be on there.
08-17-2020, 03:54 PM | #8 |
Re: brake squeak
Can be ,The new type soft lining when it gets glassed make a noise its the copper type wire imbed in the material ,try all the above fixes and 50 coup mans ,
