09-05-2020, 08:24 PM | #1 |
1939 to 1940 brake conversion
How much is involved to put 1940 brakes on a 1939.
09-05-2020, 09:32 PM | #2 |
Re: 1939 to 1940 brake conversion
All 1939 Fords had hydraulic brakes. They are the same as 1940. Should be interchangeable parts.
09-05-2020, 09:36 PM | #3 |
09-05-2020, 09:38 PM | #4 |
Assume you are wanting to go from the wide-5 to the 5 x 5 1/2 inch rims? Should just have to change out hub and drum assys.
09-05-2020, 10:42 PM | #5 | |
09-05-2020, 10:45 PM | #6 |
09-06-2020, 03:09 AM | #7 |
Just to be clear for bjk2dr.......All you have to do is swap your four 1939 hub/drum assemblies for four 1940 - 1948 hub/drum assemblies. DD |
