Old 11-30-2016, 08:30 AM   #1
Airplanemech
Airplanemech's Avatar
Default I'm Looking For A Engine...
To start off this is my first post, I'm working on a 1931 Ford Model A Murray body. It was me and my Dads project car, before we really got anywhere with it he passed away. I've been working on it with my spare time (there's not a lot lately) but I called a professional to help out. He found a crack in the block and told me the motor is no good, it was real kick in the teeth. So I'm real motivated to get this project on the road.
I'm looking for an good engine in the Jacksonville FL area Ill drive a ways it I have to. I'll take any advice about the car, there's so much about the car that I never got to learn.
Airplanemech is offline   Reply With Quote
Old 11-30-2016, 08:41 AM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: I'm Looking For A Engine...
Where is the crack? They typically crack in a few locations due to water freezing in them but can be fixed. Time to get another opinion before dropping a few grand... You wouldnt have surgery because of one doctors opinion would you?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 11-30-2016, 08:55 AM   #3
Airplanemech
Its a hairline crack from the exhaust valve to the cylinder on #2. How it was explained to me was, because the valve had a bad split so over time due to the split the valve couldn't cool so the block cracked.
Old 11-30-2016, 09:05 AM   #4
C26Pinelake
Welcome to our domain. For sure get another opinion or a couple more. I have had two blocks fixed that have lasted over five years. Wayne.
C26Pinelake is offline   Reply With Quote
Old 11-30-2016, 09:08 AM   #5
jhowes
My advice is to check with a local Model A club. There is one in Daytona beach called the Cranking A's where my brother lives. Contact him at 386-672-3185 and ask for Paul. Good luck. Jack
jhowes is offline   Reply With Quote
Old 11-30-2016, 09:23 AM   #6
1930artdeco
1930artdeco's Avatar
Mine has two exhaust valve cracks that I had repaired via stitching. If is in a water jacket my other block ran fine for years with a JB Weld patch. I would have another person look at the block. If you have the time there are several people in the PA/IL areas that rebuild engines (check the stickie at the top of the forum).
Mike
PS. welcome to the forum and nice care!
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-30-2016, 09:45 AM   #7
frank55a
For a couple of years I helped a friend rebuild Model A blocks at a local machine shop. We found that the 30/31 blocks seemed to be more prone to developing a hair line crack in the areas of the #2 and #3 exhaust valves than the 28/29 blocks. Why???? Anyway we repaired most of them with special pins. Depending on just how many cracks and how bad they are, it can probably be repaired by a good engine machine shop for under a couple hundred $$s. GET A SECOND OPINION FROM A GOOD ENGINE REBUILDER!!!!!
frank55a is offline   Reply With Quote
Old 11-30-2016, 10:42 AM   #8
Art Newland
Art Newland's Avatar
I suppose it would be nice to know the condition of the rest of the engine, especially the crank and rod bearings.
Art Newland is offline   Reply With Quote
Old 11-30-2016, 11:33 AM   #9
SeaSlugs
SeaSlugs's Avatar
yea that's true, if it needs babbit and resleeved I would look for another engine... Main reason I didn't rebuild the one in my truck was due to the fact it needs resleeved (.125 over with one cyl crusted with mouse pee) and several valve seats replaced. Didn't check the mains but would probably have everything redone at the same time if I were.
Old 11-30-2016, 11:35 AM   #10
George Miller
George Miller's Avatar
It can be fixed. I have done many over the years, not just Model A. See if you can find a shop that has been in business for a long time, that has a old guy that has worked there for a long time.
It is not a big deal you first fix the crack with tapper cast plugs, over lapped half way. Then install a valve seat, and cylinder sleeve.
George Miller is offline   Reply With Quote
Old 11-30-2016, 12:10 PM   #11
ronn
engines come up everyday on Craigslist-there should be plenty near you with a little patience.
hot rodders dump them all of the time on the cheap.
Old 11-30-2016, 12:11 PM   #12
Airplanemech
Thank you so much, I will ask around at some nearby machine shops. But for the rest of the engine I'm not sure of the condition without a full brake down and inspection.
Old 11-30-2016, 12:20 PM   #13
100IH
And as you might expect, this crack is not a candidate for JB Weld. Also, how far down into the port that the crack goes is a determining factor. At this point I'd strip it down and take it to a shop for magnaflux. Take the crank and cam also for evaluation. Then you will know what you have to work with in $$.
100IH is offline   Reply With Quote
Old 11-30-2016, 12:21 PM   #14
ronn
for example-you could get most of your money back here and end up with a free engine for a little effort.
CL
x prohibited[?] Posted about a month ago
print ◀ prev next ▶
1928 Model A Ford Chassis, Antique, Model A, A Model - $1400 (Clayton NC)
image 1 of 2
© craigslist - Map data © OpenStreetMap
(google map)
make / manufacturer: Ford
model name / number: A
1928 Model A
Running
Driving
Fully functional
Full set of White wall tires
Brakes need some work
BODY and TITLE NOT INCLUDED !!!!!
Chassis, Tires, Wheels, Motor ( every thing less Body )
1400.00 OBO
Edward
show contact info
Old 11-30-2016, 12:29 PM   #15
George Miller
If you need to rebuild the engine, then you might want a better block, if you can find one. But if it is fixed the right way it would not be a problem.
Old 11-30-2016, 06:06 PM   #16
Dale G.
Dale G.'s Avatar
I have engines for re-build and I am in Jacksonville. Call me, 731- 0367. We can discuss engine re-builders also. Dale Gosa, Jacksonville Model A's.
Dale G. is offline   Reply With Quote
Old 11-30-2016, 07:09 PM   #17
goodoldvic
goodoldvic's Avatar
Isn't Barner Todd pouring new model a blocks? Maybe that's the rescue ya need. Good luck
goodoldvic is offline   Reply With Quote
Old 11-30-2016, 07:40 PM   #18
mshmodela
mshmodela's Avatar
http://www.jbweld.com/products/highheat-epoxy-putty
STRENGTH800 PSI at Room Temp.
600 PSI at 400ºF
It's a band-aid but year 2 for my water jack crack in the very front... time will tell, so far so good.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 11-30-2016, 07:59 PM   #19
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
http://www.fordbarn.com/forum/album....ictureid=25129
This is the crack you are mentioning. If the shop can do crack repairs by stitching pins it can be repaired. No silly putty required for a permanent fix.
J and M Machine is offline   Reply With Quote
Old 12-01-2016, 06:22 AM   #20
James Rogers
James Rogers's Avatar
Not sure if you have checked with me or not.
James Rogers is offline   Reply With Quote
