03-09-2021, 02:43 AM | #1 |
1933/34 exhaust question
Was the exhaust clamp/connection at the joint on the rear cross member fixed to the cross member or just a clamp for joining the 2 pieces of pipe together at this point.
There is a hole on my chassis at this point and wondered if this is what it is for? Thanks. Graham. |
03-09-2021, 07:00 AM | #2 |
Re: 1933/34 exhaust question
It was a combination clamp and bracket attached to the frame.
03-09-2021, 02:50 PM | #3 |
Thanks David, I have a clamp that appears to be the right one so will fit it up. Hopefully it will eliminate what may be a rattle problem against the chassis in that area. Easier to do now than when a few miles have been run up.
03-09-2021, 03:34 PM | #4 |
Graham, Never truly easy as it means a trip underneath, but worse once the pipes start to sort of weld themselves together with the help of oxidation and the heat/cool down cycles. Where the bracket attaches to the frame a rubber insulating washer about 3/8" thick was installed originally to further minimize the chance of rattles/vibration.
03-13-2021, 02:51 AM | #5 |
Has eliminated the rattle problem. Thankfully 0 miles on the motor so everything came apart easy which was a relief. |
