Old 03-07-2018, 09:17 AM   #1
B-nut
Default 1934 Victoria Driver window replacement
Guys, Baffled by the removal of the door window. Original is cracked. Have black edged replacement and new weather stripping kit. Seems that we had a tudor sedan thread on similar subject several months back but I can not find it. Any constructive comments appreciated.
B-nut is offline   Reply With Quote
Old 03-07-2018, 11:59 AM   #2
cas3
Default Re: 1934 Victoria Driver window replacement
yeah there was a thread recently, i believe the plan was to tape the window up first, then install the riser mech. mr google will find it i bet
Old 03-07-2018, 02:20 PM   #3
FlatheadTed
FlatheadTed's Avatar
Try this a Tudor I think would be the same, as far as I can tell all the glasses are the same from about the centre forward .how the sliding mechanism works ect , Ted
https://www.fordbarn.com/forum/showt...ht=1934+window
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-08-2018, 12:24 PM   #4
B-nut
That's the tread ! Very helpful! From across the globe. Thanks! Also just finished installing another of set of FlatheadTed's amazing brake energizing kits so double thanks!
