Old 09-04-2021, 09:10 PM   #1
jerrytocci
Default Front end shimmy
Front end shimmies at slow speed braking . Drives fine .
jerrytocci is offline   Reply With Quote
Old 09-04-2021, 09:15 PM   #2
700rpm
700rpm's Avatar
Default Re: Front end shimmy
Must be a Model A.
Ray Horton, Portland, OR
Old 09-05-2021, 01:01 AM   #3
Synchro909
Synchro909's Avatar
Do a search. That matter has been discussed to death. All you could wish to know will be in a previous thread.
Old 09-05-2021, 07:02 AM   #4
nkaminar
nkaminar's Avatar
Warranty issue. Bring it back to the Ford dealer.
Old 09-05-2021, 07:39 AM   #5
ModelAMike1930
ModelAMike1930's Avatar
Check the wheel bearings and or the tie rod ends.
ModelAMike1930 is offline   Reply With Quote
Old 09-05-2021, 11:50 AM   #6
KenBolton
After addressing everything else I replaced the wishbone rubber ball clamp with a repro original. Did the trick.
KenBolton is offline   Reply With Quote
Old 09-05-2021, 06:56 PM   #7
jerrytocci
Thanks Ken
Old 09-05-2021, 07:19 PM   #8
goodcar
The dreaded death wobble. Check everything steering related, tie rod and drag link inserts, steering arm and pitman balls. If egg shaped, replace. Check spindles and wheel bearings for wear. Radius ball needs to be tight. Check for proper toe in.
goodcar is offline   Reply With Quote
Old 09-05-2021, 07:40 PM   #9
nkaminar
nkaminar's Avatar
Shimmy Shimmy Ko Ko Bop
https://www.youtube.com/watch?v=5mLjZRAXRRA
Warning: If you listened to 45's in the 50's this will give you an ear worm.
Old 09-05-2021, 08:14 PM   #10
Cape Codder
Cape Codder's Avatar
I have just done all that "goodcar" suggested PLUS had the end of the axles rebushed. BOTH sides were elongated! In my opinion with what I had the King Pins can move even with the locking horizontal pin installed.
Cape Codder is offline   Reply With Quote
Old 09-06-2021, 08:25 AM   #11
nkaminar
nkaminar's Avatar
There is a trick to installing the locking pins. They have to be hammered in and then the nut installed. If someone did not install them correctly then the king pins can move around a bit.
Old 09-06-2021, 10:25 PM   #12
Synchro909
Synchro909's Avatar
I NEVER hammer those cotter pins in now. I did once and ruined the axle by elongating the king pin eye.
Old 09-07-2021, 01:59 PM   #13
Rob Doe
I read somewhere recently that proper setting of the toe-in can sometimes resolve shimmy, even if other parts are worn. Not sure about the braking type shimmy, but would be worth a try if the toe-in is incorrect.
Sounds like your brakes could need adjusting. I use a cheap infrared temperature gauge to read the temps of the drums after a few stops.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 09-07-2021, 10:16 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, my temporary front axle assembly on my 28 had very loose king pin bushings, but the correct toe in, and it never had a hint of shimmy.
Old 09-08-2021, 08:31 AM   #15
Patrick L.
Patrick L.'s Avatar
It can be anything from the steering box adjustment all the way thru to the wheel bearings and anything in between. Thats quite a bit of stuff to look at and fix. Loose king pin bushings are not the problem unless maybe if they are really loose. When everything is checked and fixed if needed then set the toe-in to 1/32-1/16".
Old 09-08-2021, 10:41 AM   #16
Jim Brierley
I've found it is often looseness in the drag link ends, but all the above should be checked.
