01-12-2017, 12:35 PM | #1 |
index the timing cover?
an engine rebuilder told me he indexes the cover for true center to drive the distributor correctly. we do that on model T timers, but i never heard of it on a flathead. am i just showing my ignorance again, or is this how its done?. not sure how you would find center with the drive slot offset! thanks, skip
01-12-2017, 12:46 PM | #2 |
Re: index the timing cover?
I've never heard of it.
01-12-2017, 12:49 PM | #3 |
new to me?? shoe
01-12-2017, 01:17 PM | #4 |
The only adjustment of ignition timing is internal to the distributor on the pre 49 models (except pickups/trucks) and that is limited. I can see making a mark for TDC for the No. 1 cylinder since that can be useful to a degree when performing diagnostics but that would be the only reason I can think of. 8BA family of engines could make a bit better use of that.
01-12-2017, 01:40 PM | #5 |
I'd like to see the 'picture' of this special modification . . . as I can't imagine what he is talking about. The drive location of the timing cover bore is in a fixed spot - not way to change it in relation to the cam snout.
01-12-2017, 02:02 PM | #6 |
01-12-2017, 03:21 PM | #7 | |
01-12-2017, 03:24 PM | #8 |
Adding a TDC mark and indicator is something I do, but really not needed on a stock engine.
01-12-2017, 07:56 PM | #9 |
As a Model T owner, I index my timing cover with a pilot tool. The reason is because the timer rotor is fastened to the camshaft and the timer (distributor housing) with the contacts is a separate piece. If you don't mount the cover co-axial to the camshaft, half the cylinders fire early and the other two fire late.
Since the flathead distributor contains an integral rotor and distributor body, I don't have the same issue with my '41 as I do with the Model T. I just bolted the distributor onto the cover and drove it. |
01-12-2017, 09:10 PM | #10 |
tmiller, thats exactly what i'm talkin about. this guy said just like our T's, the cover has enough slop in the bolt holes that you can move the cover around a bit before you lock it down. like others have said, the dizzy has its own bushing, centered, for the point lobes to spin on, not on the cam itself like the T. he is near me so i'll have to see what he is doing. the guy does a lot of high dollar antique boat motors. could also be a way to get your money!
01-12-2017, 09:58 PM | #11 |
If my memory is correct the hole in the center top of the front cover is slightly smaller than the rest and the bolt for that hole ( or maybe all the bolts) have a shoulder diameter that is a little larger than normal, which serves to align the cover accurately. This is on a 59 block.
01-12-2017, 10:01 PM | #12 | |
01-13-2017, 07:00 AM | #13 |
It is correct there is a full shoulder bolt and .324 reamed cover hole which controls the radial location of the timing cover. There is also a machined shoulder which aligns in the engine block to maintain lateral locations. So, anything other than some sort of timing marking to "center" things is a misunderstanding or a scam.
01-13-2017, 08:33 AM | #14 |
Maybe he hasn't figured out that the timing cover mounting/indexing area of the block is round - 7.00" in diameter on the inside and about 8.44" on the outside. Given this, if the timing cover didn't have the flat bottom area to cover the crankshaft, you could rotate it all you want and you'd never change the relationship on how the cam gear drives the distributor - all you'd change is timing.
But - if the guy is talking about ensuring that the timing is accurate - then he'd be checking TDC on the #1 piston and validating that a 'pointer' aligns up with the crank pulley in the proper manner. And he'd just account for any discrepancies in the relationship by moving the pointer, remarking the pulley, etc - he'd do nothing with the timing cover. But, the original post didn't talk about timing - just drive alignment . . . so who knows. |
01-13-2017, 08:42 AM | #15 | |
01-13-2017, 11:23 AM | #16 |
its a 59 block i am referring to, sorry i should have posted that. i agree with all, and i have known the bolts are special shouldered, same as the six shift tower bolts,and the preasure plate bolts? JWL, i didnt see that the center one is special, i'll have to look. at any rate, i dont see how you could move that cover around at all.
01-13-2017, 01:14 PM | #17 |
I wonder how many flatheads that rebuilder has actually built?
01-13-2017, 04:56 PM | #18 |
01-13-2017, 07:34 PM | #19 |
sounds like a little over kill.
[QUO[/QUOTE]no matter where you are,or where you're at, there you are... |
