04-16-2018, 09:16 PM | #21 | |
Re: How do I buy Bob Sherman thermostats?
I do the same except I just squeeze a smaller piece of old radiator hose about 2 in . long in the hose . No clamp needed . |
04-16-2018, 11:16 PM | #22 |
Bored&Stroked and Ford Freak: I do same but use a 1 inch high piece of straight radiator hose, glued inside the stock hose with rubber cement, then one clamp inn normal location to hole the whole thing. The thickness of the inner hose piece does not hinder the flow of coolant through the stats, which are Stant units. Found that method in an older thread here on the Barn.
06-02-2018, 05:21 PM | #23 | |
Very useful guide. Thank you!
Crazy Bulk Supplements line https://diets-usa.com/crazy-bulk-reviews/ is useful for you |
06-03-2018, 09:42 PM | #24 |
Re: How do I buy Bob Shewman thermostats?
I've since suggested one improvement on this idea. Twist the single strand of wire on itself on each side so that only one strand has to be compressed by the hose instead of two. It also holds the wire in place better during installation.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
10-11-2018, 11:42 AM | #25 | |
