03-17-2022, 05:38 PM | #1 |
coil hook up
I was told today that the dist wire going into the dist to supply power to the points should be hooked to the + side of the coil,, I have a 12v system is this correct or have I been told wrong ?
03-17-2022, 05:46 PM | #2 |
Re: coil hook up
The breaker or ground control breaker would generally be connected to the + side of the coil with a 6-volt positive ground system. I use a Nu-Rex polarity tester to insure polarity after coil hook up.
Model A cars that still have the Electro-Lock ignition pop-out switch have a terminal that connects to the coil positive side. The negative side is connected directly to 6-volt power. Replacement type switches have to be wired to the points in the distributor or the switch can be connected on the power side instead. |
03-17-2022, 06:09 PM | #3 |
Re: coil hook up
Your question is to the correct coil polarity for a !2V (I assume neg ground/frame) system. For a 12V system the red wire (the one that goes to the points) should be hooked to the negative coil terminal. The black wire is hooked to the positive coil terminal.
03-17-2022, 09:28 PM | #4 |
Re: coil hook up
