Old 08-23-2021, 12:23 PM   #1
Vic in E-TN
Default Speedo Drive Gear Question
I have a 29 Pickup and the speedo has not been working for some time. I pulled the cable off the gear case on the driveshaft and found the inner cable broken. A long time ago I put a 4.11 R&P in the truck and I could not remember if I changed the drive gear in the assembly so I pulled this and discovered I had the correct 21 tooth gear. I broke the gasket when reinstalling the gear case so I looked in Snyder's catalog and they sell a set of 3 gaskets so you can set the backlash on the gear. My question is - how do you determine the backlash and what is the correct number?
Thanks,
Vic
Vic in E-TN is offline   Reply With Quote
Old 08-23-2021, 01:00 PM   #2
john charlton
john charlton's Avatar
Default Re: Speedo Drive Gear Question
I fit one gasket while I tighten up the two retaining bolts I insert a small screwdriver into the female cap end . If the drive begins to lock with zero lash I put in a second gasket this normally does the trick . A little bit of lash is fine . When the drive begins to lock stop tightening the cap or damage to the housing can result , I have never had to use three gaskets . You need a medium screwdriver for the flagged female .
John in Suffolk County England .
john charlton is offline   Reply With Quote
Old 08-23-2021, 08:40 PM   #3
Vic in E-TN
Smile Re: Speedo Drive Gear Question
John:
Thanks. Your answer makes sense.
Vic
Old 08-24-2021, 08:42 AM   #4
Terry, NJ
Terry, NJ's Avatar
Why did it break! My 29 has abut the same problem. But I found out that the speedo is very tight, not seized, but very tight. I tried oiling it and running it in with an electric drill, (Reverse) but no luck so far. I'm thinking of having Papanick do the rebuild. ($160 +).
Terry
Terry, NJ is offline   Reply With Quote
Old 08-24-2021, 09:31 AM   #5
Vic in E-TN
Terry
I don't have the speedo out yet because I found the broken cable. It is probably a good thing to check out the speedo before I put in the new cable. My speedo has 72K miles on it and I do not want to put in a rebuilt one with zero miles on it. Last week I sent an e-mail to papanick but have not heard a response. Thanks for the advise.
Vic
Old 08-24-2021, 10:25 AM   #6
john charlton
You can spin the input shaft to and fro forever and it will never free off sufficiently . The aluminum sulphate is trapped in the shaft indents and cant escape . A rebuilder will unswage the rotating magnet from the shaft and remove it . Get it rebuilt for sure .
Old 08-24-2021, 11:25 AM   #7
chrs1961815
chrs1961815's Avatar
Rebuilders don't have to turn the odometer back to zero fyi.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
