05-20-2015, 06:50 PM | #1 |
5w/20 oil OK to use?
yes I am hanging on... I have several cases of 5w/20 left over from a modern car we sold.
Can I use it in my Model A, unknown history, runs well, no smoking? Should I blend it with straight 30w, or is it OK on its own? Maybe a little STP additive? |
05-20-2015, 06:54 PM | #2 |
Re: 5w/20 oil OK to use?
i wouldnt use it or mix it with anything to use it.
if you were close by i would take it off your hands, as many newer cars spec for that Last edited by Mitch//pa; 05-20-2015 at 07:56 PM. |
05-20-2015, 07:11 PM | #3 |
I would not use in a Mural Asell it to friendwrong oil for that car goodluck
05-20-2015, 07:54 PM | #4 |
Too thin !
05-20-2015, 08:05 PM | #5 |
Too thin for me, I use 20w 50w in mine, hot down here..
05-20-2015, 08:52 PM | #6 |
Although it is much thinner than what most of us use, it no doubt would keep the metal components apart. When building a high performance motor, it is important to have as much oil flowing through the bearings as possible (to cool them). Might even find that it is better than thick oil. It is worth noting that oil film strength is not so closely related to viscosity as it used to be because of the additives they put in there nowadays. I bet I get lots of feedback on that one!!!
05-21-2015, 12:37 AM | #7 |
Crossing Russia mid-winter I MIGHT use it.
05-21-2015, 02:21 AM | #8 |
I've got a mix of 20/50 and 10/40 in mine
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
05-21-2015, 11:16 AM | #9 |
Why not use it in your 'modern' cars ? Most cars within the past decade call for that [ if not full syn].
I wouldn't use it in an 'A'. I also don't believe in additives like STP or mixing oils. |
05-22-2015, 01:30 AM | #10 |
If it were 5W-30, it'd be perfectly fine, but 5W-20 MAY be a little light when hot.
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
05-22-2015, 02:13 AM | #11 |
Should be fine in winter.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
05-22-2015, 03:49 AM | #12 |
I would sell it and use the proceeds to buy a more suitable oil.
Wayne |
05-22-2015, 07:29 AM | #13 | |
http://www.bobistheoilguy.com/motor-oil-101/ |
05-22-2015, 08:27 AM | #14 | |
I can imagine late model engines can get away with thinner oil due to tighter clearances and a better oiling system than engines that were designed in early 1900's. I have to agree with most of the responders to this thread - Use the 5W20 in newer cars as called for by the engine designers.
I Love Anything That Turns Money Into Noise |
05-22-2015, 10:42 AM | #15 |
I would not use it in my lawn mower !
V4f |
05-22-2015, 02:16 PM | #16 |
Not knowing much about this question but I would agree with this comment. It would seem like where you lived and what time of year is was.
Fred Kroon 1929 Std Coupe 1929 Huckster |
05-22-2015, 04:51 PM | #17 |
Modern low end multi-viscosity oils enable new car makers to achieve the MPG figures required by Gov.
In an A, I use SAE 30HD. I would switch to SAE 20 HD if cold weather usage is planned. Old timers who came into our family Texaco in the 1950's used SAE 20 year 'round in southern New England. Rocketsled |
05-23-2015, 01:23 AM | #18 | |
05-23-2015, 09:32 AM | #19 |
05-23-2015, 03:35 PM | #20 | |
MOST people (inc mechanics and piles of people on here) still don't understand it (even if they think they do )
