Old 10-17-2023, 06:07 PM   #1
metro1
Default Torque Wrenches
How does everyone maintain the accuracy of their torque wrench? I've had mine for quite a few years and have no idea how accurate it is. From what I've seen on the net is costs more to get one calibrated than a new one. I saw how some people hang a weight on the handle and using a math formula do it that way but that was debatable if it was really accurate. I need to install new head gaskets and need to be sure for proper torque. I guess I could buy a new one but that might not be correct either.
metro1 is offline   Reply With Quote
Old 10-17-2023, 06:50 PM   #2
Dobie Gillis
Dobie Gillis's Avatar
Default Re: Torque Wrenches
You'll be OK with a new one if it's a quality piece. I'd shy away from one from Horror Fright or any made of Chineseum. The secret to keeping one accurate is to release the spring tension when you're done using it by resetting it to 0.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 10-17-2023, 07:01 PM   #3
RKS.PA
RKS.PA's Avatar
One way to check is to borrow one from a friend whose wrench might be newer than yours....and assuming a quality brand... and do a side by side test??
RKS.PA is offline   Reply With Quote
Old 10-17-2023, 07:05 PM   #4
Dobie Gillis
Here's a DIY method to calibrate your wrench:
https://www.wikihow.com/Calibrate-a-Torque-Wrench
