Old 12-21-2019, 08:48 PM   #1
blackcoupe
Default Removing lock cylinder from 1934 Ford trunk handle
Can key lock cylinder be taken out 34 Ford trunk handle without a key. If so what is the trick, as I am not having any luck. Thanks, Jerry
blackcoupe is offline   Reply With Quote
Old 12-22-2019, 01:52 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Removing lock cylinder from 1934 Ford trunk handle
NO it can't.There is a hole at the edge of the handle and a spring loaded pin(on the lock cyl) in it .The key has to be turned 90 degrees to be able to depress it ,then the lock cyl can be removed.You need a key or someone that can pick the lock.32Phil on this site can assist you.
deuce lover is offline   Reply With Quote
Old 12-22-2019, 06:51 AM   #3
Terry,OH
Terry,OH's Avatar
The cylinder can be drilled out destroying the cylinder, without damage to the handle.
Old 12-22-2019, 10:24 AM   #4
Andy
32Phil has not been on the HAMB since Nov 3. I tried to contact him a month ago and no response. I hope he is OK.
Andy is offline   Reply With Quote
Old 12-23-2019, 10:46 AM   #5
32phil
Hi Guys
Thank You for the concern Andy.
I made the mistake of buying a new computer.....
It's been a wild ride since...... to say the least !!!
I will be leaving for Florida in early January sooooo
Early Ford Lock & Key service is on hold till April.
The good news is everyone's locks/keys etc. have been mailed out.
I will still be available for phone questions/help on my cell 845 551 5132.
Enjoy the Holidays...……... see ya at the car shows in Florida !!!
Phil
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
