05-09-2018, 07:53 PM | #1 |
Where do I find glycol based brake fluid?
By way of a back ground: my 53' Mercury has the original Bendix Treadle-Vac power brake system with drum brakes. I finished flushing out the brakes today (it has been three years since the last flush) and exhausted the bottle of dot 3 brake fluid that I bought last year. I went to the local auto parts store (O'Reillys) and all I can find is dot 3 "synthetic" brake fluid. Is it still possible to find glycol based dot 3 brake fluid? If not, is the "synthetic" dot 3 comparable with the old dot 3 glycol based brake fluid?
05-09-2018, 08:39 PM | #2 |
Re: Where do I find glycol based brake fluid?
If you have more than one parts store in your area, check the other out. Shouldn't be hard to find.
Check the writing on the bottle/can. Should say if compatible with glycol based. Worse comes to worse, there's always ebay or Amazon. If you flushed the entire system, you might want to consider dot 5 No need to flush every three years.
05-09-2018, 09:53 PM | #3 |
Googling and reading the "web", it seems as if all brake fluid is synthetic, but DOT 5 contains silicone. Multiple sources say any DOT 3 or DOT 4 mixes with any DOT 3 or DOT 4.
05-09-2018, 09:59 PM | #4 |
Farmstores and the last napa I was at, had regular dot3. But I live in the sticks. Oh course you know don't mix 3 with 5. I'm sure you can have it delivered to your door through amazon. Love or hate them they have it.
05-10-2018, 06:40 AM | #5 |
Here is a thread that spells it out. The synthetic on the bottle is just a sales gimmick. It has always been synthetic.
https://www.bobistheoilguy.com/forum...Number=2332203
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
05-10-2018, 07:39 AM | #6 |
05-10-2018, 11:32 AM | #7 |
https://www.autozone.com/brake-and-p...uid/202094_0_0
Looks like Auto Zone has it, under product details: Oil Composition:Conventional Product Details Part Number: AZBFGAL Weight: 9.25lbs Container Type: Plastic Flash Point (°F): 275 Fluid Type: DOT 3 Minimum Dry Boiling Point (°F): 480 Minimum Wet Boiling Point (°F): 0 Oil Composition: Conventional Last edited by Merc Cruzer; 05-10-2018 at 03:13 PM. |
05-10-2018, 11:35 AM | #8 |
05-10-2018, 12:05 PM | #9 |
If you have a choice, go for dot 4 over dot 3. I tested some slave cylinders years ago (in my day job) and they were failing prematurely. After switching to dot 4 from dot 3 they held up well. I've used dot 5 sometimes but have gone over to only using dot 4 on anything I have around me now, probably for the last 15 years or so.
Mart. |
05-10-2018, 01:46 PM | #10 |
AutoZone Part# AB-12
05-10-2018, 01:59 PM | #11 |
