08-03-2014, 12:49 PM | #21 |
Re: Model A wheel powder coat
I am currently working on my wheels and it takes me about one day to carefully sand one wheel before I paint them with urethane. I will have about 20 plus hours in each wheel by the time I'm finished. Brent is right. The trick is to fill nicks and pits but leave draw marks and welds and apply just the right amount of paint. If done right, there is nothing that looks better.
08-03-2014, 02:00 PM | #22 |
Not quite sure why someone would be so concerned about changing whl color and thus, spend so much time on the wheels.
Wouldnt it be easier to sell the "wrong" colored wheels and get a set that aren't powder coated and go from there? seems like 4 steps back to go 2 steps forward.............. too much "work" for me! |
08-03-2014, 05:00 PM | #23 |
I have had about 16 wheels powder coated Tacoma creme and they looked like they were wet when finished. You couldn't have done any better with paint.
08-03-2014, 05:10 PM | #24 |
I sure would like to see them.
08-03-2014, 05:24 PM | #25 | |
Bob, you are getting confused, you don't need an original fan belt or an original wiring harness to be in fine-point judging. It just needs to look exactly like it or you will receive a deduction. Plastic crap on your wheels (as you so eloquently put it!! ) can be used on a fine-point car however it WILL likely receive a deduction for poor quality craftsmanship & over-restoration just for the very reason you mentioned in your last sentence. Someone mentioned something to fill pits prior to powder painting. You can use many different products. In my shop, we use Lab-Metal as a filler, and sometimes we powdercoat the item and blocksand the partially cured paint with 80 grit paper to remove the excess only leaving the pits filled. Gary, you are pretty close on 20 hours per wheel from A-to-Z on restoring a wheel. For a shop, multiply that times $50.00 an hour X 5 wheels!! |
08-04-2014, 07:38 AM | #26 |
Terry |
08-04-2014, 08:00 AM | #27 |
i love my powder coated plastic wheels, frame, suspension, drivetrain, steering linkage, and i am sure i left out a few dozen items....
all my stuff gets primed before pc'ed to each his own |
08-04-2014, 08:48 AM | #28 |
Funny, my black rims are a tad aged... I like the look...
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
08-04-2014, 11:26 AM | #29 | |
Directly to your point, as you said, if moisture gets underneath it, it can start to rust. The base question is how does the moisture get to it? If someone did not properly apply either type of paint, we can expect to see just as you described but my personal experiences say that powder-applied paint will last just as long as a sprayed 2k urethane paint will when all things are equal. . |
