Old 10-13-2013, 12:46 PM   #1
bill44
bill44's Avatar
Default Door latch
My left rear door latch stopped popping back after opening. Upon removal I found the spiral spring was broken. I have ordered a new one, but I need a picture of how it looks when installed and how much tension should be on it. Also any tricks to get it installed correctly.
bill44 is offline   Reply With Quote
Old 10-13-2013, 12:53 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Door latch
I assume this is a Fordor, and not a Phaeton.
I only have pictures of my Tudor and Phaeton latches.
Old 10-13-2013, 09:14 PM   #3
bill44
bill44's Avatar
Yes, It is a closed car 4 door, Murray body.
Old 10-14-2013, 07:53 AM   #4
Jon
Jon's Avatar
Tom, could you post pictures of the Tudor latch? I was trying to get my drivers side door latch apart last week and bloke it. I managed to force a spring in there and make it work for a 500 mile trip this past weekend. I tried removing the handle, turn 1/4 turn, pull out, and it wouldn't budge. What am I doing wrong there?
Thanks.
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 10-14-2013, 11:49 AM   #5
Tom Wesenberg
John, Here's the link to what I posted.
http://www.fordbarn.com/forum/showth...dor+door+latch
I wonder how different the Fordor latch would be?
I have a spare latch in the basement. I'll have to see if it's what Bill needs a picture of.
To remove the door handle in my picture, you must remove the 2 screws on the outside handle, then turn the handle 45*, or 1/8 turn, just as though you were going to open the door, then wiggle it and pull at the same time. Spray some Kroil onto the shaft to help it slide out. I also push in on the latch to take a little pressure off the shaft, as I wiggle and pull on the handle.
Old 10-14-2013, 04:48 PM   #6
Tom Wesenberg
I just checked my spare latch in the basement, and it's from a 1930-1 Tudor. I'm not familure with the latch on a Fordor, as I don't ever recall working on one.
Old 10-14-2013, 05:24 PM   #7
karasmer
I just replaced the spring on my roadster latch. I ground down the press tabs holding it together so you can open it up, put a spring in from my spring parts bin and tack welded it back together and now it works great.
karasmer is offline   Reply With Quote
Thread Tools
Display Modes
