#1 |
Attached are photos of a 59 engine from a 45-46 Army AF fire truck. The stamping on the bell housing has an imbedded "L". The sleeved cylinders are 3.18" dia. The block is factory relieved. Is this a "L" block engine?
#2 |
The engine in my roadster is a 59-L factory relieved block that did come from a truck so I would think that is also the case for yours.
#3 | |
![]() Quote:
Bill |
#4 |
In my opinion, it is not a 59L block nor is it factory relieved, my reasons follow:
1- The L is indented (recessed), smaller, and located on line with lot numbers, rather than raised, and same large size next to the 59, as has been the norm. 2- The Ford factory relieved blocks I've seen have the relief in an hourglass shape, rather than in straight parralell cuts.
Alan |
#5 |
That's a factory relief
#6 |
#7 |
Yes, that looks like the standard Ford relief which were all done in a straight line with a broach bar.
No, it is not a 59L. |
#8 |
Factory relief.
That is definetly an "L" cast in the block. No, it is not an "L" block. |
#9 |
Thanks one and all...
#10 |
This is an authentic 59L engine. It has a 3 3/16" bore, factory relieved block. It came out of an early '46 tudor. As I understand it many early production '46 Ford and Mercurys had surplus military engines.
Tom |
Thread Tools | |
Display Modes | |
