03-17-2022, 09:06 PM | #1 |
Welding Stainless??
Just curious. What's involved with MIG welding stainless? Wire? Gas? What else?
Thanks!
03-17-2022, 09:52 PM | #2 |
Re: Welding Stainless??
I've welded stainless with MIG & gas. basically S.S is steel with high nickel content. The weld will have a different color and will rust. If you can find S.S. mig wire that may work better. I've shortened S.S. trim, closed the ends and tacked the ends together. then put some silver paint over the weld. no one ever noticed the difference.
03-17-2022, 09:56 PM | #3 |
Pure Argon for SS usually expensive so get a small bottle to keep. SS wire 304 alloy??Newc
03-17-2022, 10:38 PM | #4 |
Yep, you cab get a small (or large) spool of SS MIG wire. Argon gas.
And like fordor41 said regular steel MIG will "work". An old trick used to be able to cut stainless with a torch. Run a bead of regular welding rod or wire where you want to cut. |
03-18-2022, 08:50 AM | #5 |
I have had good luck welding stainless mouldings with my Cobra torch and stainless welding wire.
03-18-2022, 09:07 AM | #6 |
03-18-2022, 09:41 AM | #7 |
Finished out and polished, the color won't quite match, but exact color isn't noticeable on a shiny piece of trim unless you know what you're looking for. If being point judged on the Concourse, you'd have a small but real chance of squeaking by unseen on color.
Alan |
03-18-2022, 10:34 AM | #8 |
I always use TIG for Stainless.
03-18-2022, 01:22 PM | #9 |
I have an oxy acetylene set up. Might be worth a try.
03-18-2022, 01:40 PM | #10 |
Tig
03-18-2022, 01:41 PM | #11 |
Pete here is the instructions for setting your flame for stainless.
03-18-2022, 11:06 PM | #12 |
I just buy argon for my bottle. Better Tig overall for steel (not needed but) or best/needed for SS and aluminum. I flip it to tig or mig as needed on that bottle. I don't need to weld a ton. But when I need it, it's there.
You can always weld steel with argon. You can't weld other without. Last edited by Tinker; 03-18-2022 at 11:30 PM. |
03-19-2022, 04:48 AM | #13 |
Thanks everyone!!
03-19-2022, 07:50 AM | #14 |
All SS will show som surface rust if not cleaned & passivated. Tig welding with correct weld rod / wire on stainless trim is the way to go. Aggressive Cleaning including passivation before & after removes the surface iron molecules. All bright work stainless is cleaned & passivated at the end of processing to minimize remove the surface iron molecules that cause rust.
Nomad Last edited by AnthonyG; 03-19-2022 at 09:49 AM. Reason: Typo |
03-19-2022, 07:55 AM | #15 |
If your filler rod is the same alloy as the piece being welded it will do much better.
Tig is the way to go but I’m not good enough (yet, if ever) to make the weld disappear |
03-20-2022, 11:39 PM | #16 |
If you have a brush to clean as you go. Stainless brush is what I would suggest.
