Old 02-10-2018, 06:37 AM   #1
LizardsA
LizardsA's Avatar
Default Question about 12-volt negative earth
Good day,
I have been asked to work on a friend's Model 'A' that has a 12-volt negative earth conversion. I eagerly ripped out wires because this looked like a terrible "botch" job. I am now in a position to begin rewiring.
My question is: can I rewire this car as per the standard Model 'A' electrical diagram, or do I need to make changes for any reason?
Further questions
1. Will the 6-volt condenser work on a 12-volt set-up?
2. The coil is a 12-volt coil;
3. Do I have to wire the vehicle with a negative earth?
4. Does the wiring change on the amp meter?
I do apologise for the strange questions, but I am a bit of a troglodyte when it comes to vehicle electrics.
Mike
LizardsA is offline   Reply With Quote
Old 02-10-2018, 07:50 AM   #2
chap52
chap52's Avatar
Default Re: Question about 12-volt negative earth
Go to the "Search" tab at the top of this page, click on "Advanced Search" at the bottom of the pop up. Enter "12 volt conversion" in the subject box and highlight "Model A 1928-1931). You will get you a boatload of info on the subject.
This is a good way to access previous posts. I know this subject has been covered many times before. Hope it helps, Chap
chap52 is offline   Reply With Quote
Old 02-10-2018, 07:53 AM   #3
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Check out http://cedarcreekas.org/TechTopics/1...rn_Signals.pdf
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 02-10-2018, 10:00 AM   #4
kd4lok
kd4lok's Avatar
Think it might have been best to fix what, if anything, was broke first
before ripping out all the wiring.
Bob
kd4lok is offline   Reply With Quote
Old 02-10-2018, 10:21 AM   #5
jrelliott
jrelliott's Avatar
The wiring is the same for 6V Positive Ground or 12 V Negative Ground with the exception of the 12V coil instead of 6V coil( You can use 6V coil with a dropping resistor). The coil wires are reversed on the coil as are the wires on the amp meter. You just have to change all the bulbs. The condenser in the distributor will work no need to change.
Just hook up the ground of the battery to the frame ground and the positive cable to the starter.
jrelliott is offline   Reply With Quote
Old 02-10-2018, 10:43 AM   #6
LizardsA
LizardsA's Avatar
Thanks everyone.
So, jrelliott, it looks like the wiring is the same as the wiring diagram, except for the couple of changes you mentioned?
Kd4lok, the wiring was a mess to start with, nasty "short cuts" and stupidity all over theplace - none of it made any sense! Hence, it was easier just to clip it all off and try and get it back as close to original as possible, as long as there was no complications involved.
Old 02-10-2018, 10:48 AM   #7
redmodelt
redmodelt's Avatar
AS the car has been running 12 volt, just rewire as you would a 6 volt system except as stated above the coil and meter. I understand messed up wiring and sometimes it is safer to pull it all out and start fresh. A few have come into the shop, that was the condition when they came in. The previous owner added wires here and there and some went no where or had spliced in bits here and there to replace tatty wire.
If you don't have a tester, look on line how to check the polarity of the coil. The car will run with the leads reversed but not as well.
Old 02-10-2018, 12:03 PM   #8
LizardsA
LizardsA's Avatar
Redmodelt, the car has a coil with a "+" on one side, and a '-" on the other - I'm sure that will do the trick
Old 02-10-2018, 12:11 PM   #9
redmodelt
redmodelt's Avatar
Should.
Old 02-10-2018, 12:33 PM   #10
kd4lok
kd4lok's Avatar
As part of the wiring update, if not already existing, I Would add a Battery Disconnect switch in the GND cable to the battery.
Bob
Old 03-05-2018, 11:12 AM   #11
LizardsA
LizardsA's Avatar
Just to check on the good advice provided above: I keep the wiring the same as if it was a 6-volt positive earth system, but make the following changes:
1. Swop the wires over on the coil;
2. Swop the wires over on the amp meter;
3. Do I need to swop the wires over on the ignition switch?
4. Will there be any change to the wires going to the distributor?
As always, your assistance is most welcome!
Mike
Johannesburg, South Africa
Old 03-05-2018, 03:47 PM   #12
Patrick L.
Patrick L.'s Avatar
#3. no
#4. Yes. The - primary wire will now go to the points which actually refers to your question
#1.
Old 03-05-2018, 10:04 PM   #13
LizardsA
LizardsA's Avatar
Thamks PatrickL - how does one do this without it looking like another big mess?
Old 03-05-2018, 10:07 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
You don't need to touch the popout nor the distributor.
Old 03-05-2018, 11:58 PM   #15
LizardsA
LizardsA's Avatar
Tom Wesenberg: if the answer that PartickL gave to my questions:
3. Do I need to swop the wires over on the ignition switch? - "no"
4. Will there be any change to the wires going to the distributor? - "yes"
How will #4 be achieved?
Old 03-06-2018, 08:03 AM   #16
Patrick L.
Patrick L.'s Avatar
Sorry I wasn't clear. Switching the primary wires on the coil is all thats required. The point I didn't make very clear was that the negative [-] primary coil wire now ends up going to the points.
