10-31-2016, 09:28 AM | #1 |
'36 eng. idetification.
I have a complete '36 engine I have for sale. This is the year they came with 2 different styles of bearings. Buyers want to know which style mine is, Is there a way of telling without opening it all up ??? Selling it as running when pulled from the car, I hate start tearing it down...... Hope for some help !!!!!!! Thanks Terry
10-31-2016, 10:12 AM | #2 |
Re: '36 eng. idetification.
On the driver's side,top front of the engine between intake manifold and the head there could be an LB stamped.
Not all LB type blocks were stamped. Only other way I know of is to measure the main bearing studs. 3.25" on an LB type block. |
10-31-2016, 10:22 AM | #3 |
This should help:http://www.fordbarn.com/forum/showth...5301&showall=1
Basically,you'll have to drop the oil pan and measure the main bearing studs,center to center.If it's a 1935-36 LB block,the measurement should be 3 1/4 inches. I believe (according to the link) all 1936's were LB's.Only some of the 35's were LB's. LB's are getting hard to find and pretty expensive. |
10-31-2016, 05:20 PM | #4 |
I am not sure if this is true on engines in the USA, but I have been told to look for a small Hole on the right hand side of the engine between the Engine Mount and the Timing Gear Cover. In this picture, (centre of picture) you can see the Cork Sump Gasket is visible. This Engine is the LB engine with the Slipper Bearings.
10-31-2016, 05:21 PM | #5 |
Here is a larger photo showing the Hole that I refered to. |
10-31-2016, 05:44 PM | #6 |
Page 364 of the 36 service bulletins has a picture of the 3 "LB" blocks I have none have "LB" stamped anywhere between the headsand manifold |
10-31-2016, 06:12 PM | #7 |
I've read here on the barn that the hole that mercman from oz meantioned was on Canadian blocks
10-31-2016, 06:14 PM | #8 |
Do u have any pics of these dents to show us Kurt in NJ?
10-31-2016, 06:50 PM | #9 |
All I have at home is the pic from the service bulletins --and it looks like the phone turned it
10-31-2016, 07:35 PM | #10 |
I have never seen that before. Very cool!
1936 service bulletins? |
10-31-2016, 08:23 PM | #11 | |
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 11-01-2016 at 10:55 AM. Reason: added some clarification and pictures |
10-31-2016, 08:50 PM | #12 |
Great information !!! Thanks I'll be looking at this motor tomorrow. Anyone else ??
10-31-2016, 11:59 PM | #13 |
Here's picture of my '36 block with LB stamping.
11-01-2016, 07:23 AM | #14 |
Terry, it might be a good idea to post a few photos of your engine so the experts here on the Barn have a better idea of what you have. Now you know the areas to get the photos of to help with the ID!
11-01-2016, 09:27 AM | #15 |
I've always had extra interest in "LB" engines ... probably because I've always had extra interest in '35 Fords. Unfortunately more misinformation is routinely posted about the subject which causes confusion.
"I believe (according to the link) all 1936's were LB's.Only some of the 35's were LB's." Not to pick on anyone, but that is incorrect. My experience and research indicates that "LB" engines were introduced for the beginning of the 1936 model year. Production of the engines began in September 1935. If anyone has any credible evidence that 1935's came from the factory with "LB" engines it would be good information. There is more wrong information on the internet than correct information ... folks just keep repeating the stuff that's wrong. I personally have had an October 1935, based on serial number, "LB" engine that came out of a 1936 model. I have had 4 "LB" engines ... still have 2 with one on the stand right now. None have or had stamps. Great posts by "38 coupe" and "Kurt" ... some of us get too deep on details ... I don't think it hurts. I can be wrong and hope that the discussion will refine my/our knowledge.
"Remember that when it comes to intelligence, half of all of us are below average." |
11-01-2016, 11:25 AM | #16 |
Oops...Sorry guys.I misread #14 in the link. 38 Coupe stated that production of the LB's started in '35 and that in 1936,both blocks were used.My bad.
Hoop....Where is the serial number that you mentioned? Are you referring to the stamp on the transmission bell housing? |
11-01-2016, 12:04 PM | #17 |
Transmission stamp plus car history directly from owner.
11-01-2016, 02:10 PM | #18 |
Over all the LB was a short lived run wasn't it?
11-01-2016, 04:01 PM | #19 |
Here's a good pic showing the profile of the "LB" pan. Maybe someone has a babbitt pan and can post a similar photo for comparison.
Rob, surprising that some are still around. My coupe was owned by a Ford dealership mechanic who knew what to tweak ... "LB" engine, '39 gears, later steering, but well within MY idea of what's acceptable original modification. DON'T ever sell your car!!!! That is a "forever" car. oilpan.jpg
"Remember that when it comes to intelligence, half of all of us are below average." Last edited by Hoop; 11-01-2016 at 04:11 PM. |
11-01-2016, 07:15 PM | #20 |
