01-29-2023, 05:48 PM | #21 | |
Re: Putting a drain plug in a gas tank?
The plug slides approx 1/2 way into the hole, with the nut on the outside(bottom of the tank). When I tightened the nut the neoprene held the bolt steady and I was able crush and expand the plug to seal the hole. I tried it at NAPA when I bought it and it worked in the store. That was last April. The plug and the hole are dry as a bone. Checked yesterday when I took the car for a drive. JPL |
01-29-2023, 09:39 PM | #22 |
Give McMaster Carr at try for automotive gas tank self sealing drain plug. They show a brass one for $18.33.
01-29-2023, 10:06 PM | #23 |
A little off topic, but close enough. I had a split in the plastic gas tank on my Ranger pickup. Knowing it takes a spark or flame to ignite gas or fumes, I crawled under the truck with an old Western Electric electric soldering iron, real hot, and melted the plastic enough to fuse the leak shut. Still holding 10 years later.
01-30-2023, 11:12 AM | #24 | |
Smooth move, Counselor! Did it not occur to you that there MIGHT be some SPARKS involved to make that "ELECTRIC" soldering iron "real hot"? Even more-so if there happens to be a malfunction in the soldering iron's inner workings! And, did you GROUND the truck before you started that project, just to preclude any stray STATIC electrical discharge? Coop . |
