Old 02-22-2011, 10:24 AM   #1
Holeinthehead
Arrow 28 model A VIN location
Help, help!
The stupid Secretary of State "has a problem" with my title. I bought car from a guy in Texas and the car has a Texas title which I surrendered in order to get my Illinois title. Now there is a "problem"
Can anyone tell me where the VIN is located on a 28 A ?
Holeinthehead is offline   Reply With Quote
Old 02-22-2011, 10:35 AM   #2
Steve Plucker
Default Re: 28 model A VIN location
You raise a question that has been asked time and time again...
There could be many senario's as to just where the "VIN" is located.
First we know nothing about the vehicle you have.
In the begining, Ford stamped the left side of the engine with a engine number on the engine number pad. Then, when the engine was dropped into a chassis at the assembly line, that number was then put on the top of the left side frame member in the vicinity of the cowl...you must raise the body off of the frame to read it...sometimes it is there, sometimes it is not due to the 80 plus years of service if you have an original, assembled vehicle.
NOW...if you do not, then there is another can of worms to open...
If the car you have was peiced together, then the numbers could be in the same spot or they could have been stamped elsewhere...or not!
Lots of senarios...ask the previous owner if he had the numbers stamped other than the above.
I am sure others will chime in on this delima!
Pluck
Old 02-22-2011, 11:11 AM   #3
rotorwrench
rotorwrench's Avatar
Texas used to be pretty lax on checking the VIN numbers. After 1985 or so, they started requiring a VIN check on any vehicles coming into the state from other states. If the VIN is not on the engine, they require a pencil rubbing of the number from the frame.
I purchased a 1929 Sport Coupe here in Texas back in 1990 that had originally come from Tennesee back in the late 1970s. Since the car was already titled in Texas, it wasn't required to check the VIN so I had no problems transfering the title. After I got to looking at it while performing some minor repairs to the engine, I found that the number on the engine was completely missing. I don't know if it was a replacement engine or not but the number pad on the left side above the water inlet was rusty and blank. It always made me wonder how the guy I purchased it from got it registered in Texas after coming from Tennesse. I could tell he never took the body off the frame. He either had a pencil rubbing that I don't know about or they just plain didn't check it when he transfered the title back in the 70s.
Kerby
Old 02-22-2011, 11:26 AM   #4
1931 flamingo
1931 flamingo's Avatar
You might try doing a search on this forum and the EV8 forum as the problem in Illinois was discussed extensively. They are being very picky, even going after previously registered (in Illinois) vehicles. Not pretty.
Paul in CT
Old 02-22-2011, 12:09 PM   #5
MikeK
MikeK's Avatar
Illinois recognizes only the frame number on Model A's. You will have to raise the body, find and clean off the number, then have a rep from the state police witness it and sign off.
If the frame number does not match your title, you surrender the old title and apply for a new, bonded title. The bonded title will require you to post a cash bond 1.5X the SOS's estimated value, which is usually sky high and independent of any paperwork you have showing a lower value.
If your frame number matches the title, you may still be required to carry a bonded title, depends on which way the wind is blowing in Springfield.
After three years of no claim against the VIN, you apply for a standard Illinois title. Theoretically you can apply for refund of the bond "Pursuant to available bond pool reserve" and minus fund management fees, of course.
NEVER (ever, ever, ever!!) disclose to anyone the VIN on your bonded title. Claims against your title will materialize out of the woodwork.
MikeK is offline   Reply With Quote
Old 02-22-2011, 03:52 PM   #6
Aerocraft
Aerocraft's Avatar
I live just a few miles north of you at Rt. 59 and 83rd street. I would be happy to make a "House call" (free of course) to help. The State of Illinois has been a real pain and I have recent experience in getting an out of state car registered. I am retired and available (almost) any time. Gar Williams 630-904-8416 [email protected]
Aerocraft is offline   Reply With Quote
Old 02-22-2011, 04:12 PM   #7
Slantwindshield
Illinois sucks on older car titling!!!!!!!!!
Slantwindshield is offline   Reply With Quote
Old 02-22-2011, 04:35 PM   #8
Louis
Holeinthehead,
What was said that brought the problem of the VIN# up?
Did you tell them that you did not know the VIN # of the car because it was an antique?
was the Vin# on the Texas title? if so why would they not use that VIN#?
Louis is offline   Reply With Quote
Old 02-22-2011, 07:08 PM   #9
Aerocraft
Aerocraft's Avatar
The DMV in Illinois has recently decided that any out of state car manufactured before 1941, being brought into Illinois for registration and title, is required to have the VIN verified. The verification, in the case of a Model A, requires the removal of the body to gain access to the number stamped on the frame. The Illinois DMV is smart enough to know where the numbers are stamped on the Model A. There is now a procedure that new Model A owners (of out of state cars) in Illinois must follow. The worst part is the body removal. A friend near me has just gone through the process and indicated it is not as scary as some people are reporting. Gar Williams
Old 12-31-2020, 09:02 AM   #10
ross3655
Is there such a thing as a “Car Fax” report for a 28? I have a VIN and plate number but Car Fax does not recognize it.
ross3655 is offline   Reply With Quote
Old 12-31-2020, 10:26 AM   #11
dean from bozeman
dean from bozeman's Avatar
What possessed Henry to put one of the VIN numbers in such an inaccessible place? So many frames are pitted because of standing water. If it would have been stamped on the outward side of the frame rail it would have be accessible and perhaps would not have suffered as much pitting.
Okay, I imagine that Henry put it there to easily match up the engine and frame and did not consider future identification problems, but heck, I do need something to complain about.
dean from bozeman is offline   Reply With Quote
Old 12-31-2020, 10:45 AM   #12
ronn
so Dean,
Henry wtd to sell you another car in 5 years.........
who cares about vins anyway?
Happy New Year!
lol
Old 12-31-2020, 11:55 AM   #13
Gary WA
Gary WA's Avatar
Originally Posted by Holeinthehead View Post
Help, help!
try this,thanks to supplier of photo!
www.whidbeymodelaclub.com
Old 12-31-2020, 12:04 PM   #14
rotorwrench
I don't think the Carfax system will pick up on cars VINs that aren't in the database that their computer system draws from. Their database is likely only 20 years old or so and uses the modern standard for VIN sequence.
Old 12-31-2020, 12:26 PM   #15
dean from bozeman
I had to laugh when I first registered A495 for a title in Montana. No inspection but the woman at the desk was, 'Wow, I've never seen a VIN number that low.'
Old 12-31-2020, 04:15 PM   #16
JayJay
Hard for me to imagine that there is any state where anything regulatory is more of a PITA than California, but apparently there is. California does require verification of VIN on cars brought in from out of state. My Town Sedan came into California from Wisconsin but all the previous owner (who brought it in) had to do was clean off the number on the engine plate and voila, a California title.
Funny thing - I was digging around under the rear seat and found some shreds of a Janesville, WI newspaper. Haven't been able to date it precisely but a hint - all the phone numbers in the ads are four digits only! There is a historical society there who may be able to help me.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 12-31-2020, 04:47 PM   #17
jimalabam
jimalabam's Avatar
ID (VIN) numbers were not unique to Ford, almost all cars have an FBI # somewhere on the car's frame...
jimalabam is offline   Reply With Quote
Old 12-31-2020, 05:32 PM   #18
Brad in Germany
Brad in Germany's Avatar
Just take the original Instruction Manual to the MVA/DMV/Secretary of State and show them the bottom of page 4 which clarifies for them that the engine number is the serial number of the car (see red arrow in this scan of an original Instruction Manual):
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 01-01-2021, 10:17 AM   #19
ronn
well done Brad.
only problem is many engines were chged and you have a big problem if you are using a SBC engine.
Cali is a pretty easy state. worst state in the nation appears to be Nebraska.
and that is a matter of county.
OH can also be a bit of a headache, but all are doable with a little patience.
Old 01-02-2021, 09:44 AM   #20
brito36
I live in Illinois and purchased a sedan delivery which had a Michigan title. I applied for an Illinois title and plates. The Secretary of State sent me a letter and requested that I send them a photograph of the number on the frame along with a document of inspection signed by the police verifying the number. Had that done, returned it to the Secretary of State and received my Illinois title. No problems.
brito36 is offline   Reply With Quote
