12-27-2012, 02:54 PM | #1 |
1928 multi-disc clutch
Is there an easy way to spot this on a '28 Model A by just looking from the outside of the housing? Is it hard to change over to a single disc clutch? Or do you have to stay with the multi disc?
Car I'm looking at is an August 1928 build. I don't really care for the idea of maintaining a '28 with their early features compared to say a '30 or a '31. Trying to talk myself out of this car |
12-27-2012, 03:00 PM | #2 |
Re: 1928 multi-disc clutch
Ok, The 28 had a 3/4" shaft for pedals all others 7/8".. You have to change Trans, flywheel, bell housing, & chutch assy. along with the pedals..
12-27-2012, 03:03 PM | #3 |
The bellhousing looks alittle different. Has a smaller pedal shaft and a flat inspection cover. All of which will need to be changed to change to the later clutch along with the transmission housing. I have heard of a couple of people doing some machine shop work to allow clearance for the later clutch inside of the 28 bellhousing. I do not know the details of what all is invloved in doing this. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
01-22-2013, 03:06 PM | #4 | |
Does it HAVE to be machined or could grinding suffice? What actually hits? I may have to go through this in 2 weeks. Last swap I bought a RHD bellhousing and then found it to be AR and will most likely want to fit my best engine that is currently a LHD single plater. So, if I can modify a RHD AR all is good, or I have to chase up a RHD 29 bellhousing. |
12-27-2012, 03:11 PM | #5 |
See my picture in #17 reply on this thread:
http://www.fordbarn.com/forum/showthread.php?t=92644 BTW, no need to fear the multiplate, unless the flywheel is shot. They can be tough to find a good one. |
01-22-2013, 03:37 PM | #6 |
11-28-2014, 12:49 PM | #7 |
01-22-2013, 07:14 PM | #8 |
Pooch, the flywheel will hit the inside of the bellhousing. Like I said before I do not remember what the whole modifiaction intails as far as cleanancing. About all I can rememeber is being told id a V8 pressure plate was used. With some measuring I will bet you can figure it out. Rod
01-22-2013, 08:35 PM | #9 |
I have a multi disk in my 28 tudor. So far it' the best clutch ever.
01-23-2013, 01:10 AM | #10 |
OK Rowdy, will sort it out down the track when I get it home.
04-08-2022, 01:29 AM | #11 |
When you get it sorted out be sure to keep the rest of us 28ers informed too
01-23-2013, 03:21 AM | #12 |
I have made the conversation of the 28 belhousing and transmission and installed a later pressure plate and lightened flywheel so I could use the early pedals. When completed you would be unable to identify, from a visual inspection, that anything had been changed. This conversation was on a Very Early 28 with left hand brake and smooth pedals. I did not make any change to the floating brake system.
For starters the 28 bellhousing has to be machined to accept the later transmission input shaft and throwout bearing sleeve and bearing retainer; the multidisc fork has to be changed to a later fork as the multidisc fork is too narrow for the later throwout bearing; the shaft size that carries the fork is the same size in both early and later bellhousings. If you use a cone pressure plate it is not necessary to make any changes to the inside of the 28 bellhousing for clearance. I had a regular flywheel cut down to 39 lbs including the new ring gear; the flywheel was surfaced smooth, drilled and tapped for the pressure plate (Joe Way who posts here on the Ford Barn did the work on the flywheel). If you choose to use the tractor pressure plate, with the counter weights on the outside then you have to do some grinding to the bottom inside of the bellhousing to make clearance. Would also suggest you use the early arm on the throwout shaft as you get better alienment with the clutch pedal. Ron |
01-23-2013, 09:58 AM | #13 | |
I am so glad you posted this...Now you need to take it a step further and do an article about the conversion for Model A News or The Restorer. They are in dier strights for those in the know to do articles for them! What do you think my friend? Have a good one at Turlock. Pluck |
01-23-2013, 04:45 PM | #14 | |
What if I was to use the 28 bellhousing AND gearbox on the back of the 29 motor , would this skip the machining process? Do I HAVE to use a 29 input shaft/To bearing/retainer? Are they different? You had your flywheel lightened, and you had clearance, so I am not sure if the info I heard will still mean the standard 29 flywheel will foul on the 28 bellhousing. |
01-23-2013, 05:25 PM | #15 | |
01-23-2013, 05:04 AM | #16 |
Ron, by CONE pressure plate, do you mean the same as DIAPHRAM pressure plate?
If so, is the pedal easier to push, and what year is the pressure plate from? |
01-23-2013, 10:05 AM | #17 |
Can the people who have made all the changes please tell me & others what you gained by doing all this work ?? Not long ago I took apart a multi set up that had 66,514 original miles on it, worked as new & looked the same.. And yes, I do run one in my "28"..
01-23-2013, 01:07 PM | #18 |
I was just asking for the fact I have a LHD 29 and I want to convert to RHD and I only have a spare multidisk bellhousing.
If it involves a fair bit of work including machining, it will prob be easier for me to just source a later bellhousing. I will admit, I much prefer the round pedals. |
01-23-2013, 01:24 PM | #19 |
When I get back from rhe Turlock Swap Meet I will try to get some pictures made of the conversion and post them on the Barn.
Tom, instead of using " Cone " I should have said "Diaphram". The Diaphram Pressure Plate has a much lower profile. rON |
01-23-2013, 05:44 PM | #20 |
The transmission Input Shaft for the multi disc clutch is entirely different than the later input shafts; the multi disc input shaft is set up to attach the clutch to the shaft. Also the throw out bearing is different than the later throw out bearing which attaches to the sleeve of the bearing retainer.
Ron |
