Old 06-20-2022, 07:44 PM   #1
Kiwitrucker
Default Equalizer Cross Shaft Brake Rods
While rebuilding the brakes on my early '28 with the split cross shaft, I noticed someone has replaced 3 of the rods with adjustable ones. I set the rods to what I thought was good but find I now have fantastic front brakes (where the remaining original rod is on one side) and virtually no rear ones. Would anyone know what the correct front and rear non-adjustable rod lengths are?
Kiwitrucker is offline   Reply With Quote
Old 06-20-2022, 09:27 PM   #2
old ugly
old ugly's Avatar
Default Re: Equalizer Cross Shaft Brake Rods
i just tried looking that up the other day.
what i found was, on the first page of the ford bulletins book is where it talks about the early brake rods and adjusting them.
check those bulletins and see if what you need is in there.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
