06-10-2022, 01:27 PM | #1 |
front fender exchange
any chance '40 deluxe front fenders can be replaced with '39 deluxe easily? same question on grille assembly. thank you.
06-10-2022, 04:47 PM | #2 |
Re: front fender exchange
Front fenders YES, to my knowledge the perimeter of the 39 fenders and the 1940 car fenders are the same.
Grill assembly NO, the hood is different (39 hood the same shape as 1940 standard). The hood would need to be replaced also. In addition early 1939 had a different latch than later 1939 (and 1940 standard) so care would need to be taken to make sure there is a match. |
06-10-2022, 05:30 PM | #3 | |
I will add... the 39 front fenders have a different shape at the lower - front edge. If you want concourse correct, then you'll need to find '39 fenders.
06-11-2022, 12:01 AM | #4 |
MEMBER EMERITUS
39 fenders will also need a slot cut out in the opening to accomodate the '40 headlamp buckets. Last edited by swoopNZ; 06-11-2022 at 04:06 AM. |
