Old 08-20-2021, 03:25 PM   #1
MickyD
MickyD's Avatar
Default 28 roadster front seat
How do you remove the front seat back in a 28 roadster? I am getting it ready for the paint shop. They will be painting the inside and outside.
MickyD is offline   Reply With Quote
Old 08-20-2021, 04:02 PM   #2
wrndln
Default Re: 28 roadster front seat
If you remove the seatback upholstery, it is almost impossible to reinstall it. There is a flap the goes over the wood belt rail and stapled to the wood. Then hidem is installed to cover the tacks securing the front seat flap. When the seatback upholstery was initially install, there was "salvage" material that allowed the installer to stretch the upholstery before tacking it to the wood. The salvage material was then cut off. That means there is little upholstery material left to stretch the the seatback material to the beltrail. I would recommend you mask off the seatback upholstery then paint the inside of you roadster.
Old 08-20-2021, 05:42 PM   #3
Werner
Werner's Avatar
Micky,
in my roadster, the backrest was fixed with wood screws starting from the mother-in-law seat. In addition, as previously written, the overhang of the upper backrest padding must be removed the brackets. This can be restored well again.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-20-2021, 06:01 PM   #4
MickyD
MickyD's Avatar
Thanks all. I will have them mask it off.
