Old 05-13-2010, 01:35 PM   #1
Special Coupe Frank
Special Coupe Frank's Avatar
Default Copper headgaskets - width at skinny part between cyls ?
I just received from Snyders my new head gasket, moly-studs & nuts, and tapped water outlet for my '28.
I've read commentary about Fel-Pro and their "R-3" copper gasket which was designed to work on engines with large re-bores (0.100"), which leaves less gasket between the cylinder bores between 1 & 2 and 3 & 4.
Does anyone have a width on the stock gasket at this spot ?
( I have a blown R-3 I can measure...)
Thanks !
SC Frank
Special Coupe Frank is offline   Reply With Quote
Old 05-13-2010, 01:49 PM   #2
Rowdy
Default Re: Copper headgaskets - width at skinny part between cyls ?
I beleive Vince's website has that info. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-13-2010, 03:15 PM   #3
Benson
Benson's Avatar
Thanks !
SC Frank
I have an UNUSED Fel Pro 7013 R-1 here. It measures .030.
Benson is offline   Reply With Quote
Old 05-13-2010, 06:06 PM   #4
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Don't you mean .300? I've never seen one that was .030.
Barry B./ Ma. is offline   Reply With Quote
