12-16-2018, 09:52 PM | #21 |
Re: Slow leak
Yes it will stop leaks but get it on the rims and it will cause RUST big time, then you will have to remove the tire sand the rim and repaint it. I would run from it. I used it once in my lawn tractor and regreted it, never again.
12-17-2018, 09:11 AM | #22 |
Re: Slow leak
Brattons,all tubes are imports.
12-17-2018, 09:47 AM | #23 |
Re: Slow leak
I don't mean to be gross, but I check for valve core leaks by spitting on my finger and wiping the spit across the tire valve stem. It works like soap. If there is the tiniest slow leak, a bubble will soon appear. Have diagnosed at least a hundred farm tubes, Model A tubes this way.
12-17-2018, 10:06 AM | #24 | |
Re: Slow leak
Betcha a gazillion others do the same.
12-17-2018, 01:54 PM | #25 |
Re: Slow leak
I would not recommend this stuff. It just makes a mess and makes it impossible to patch the tube if you want to at a later date. And NEVER use it in a modern tire. It plugs up the valve stem sensor and your dash indicates a flat tire all the time (if so equipped).
12-17-2018, 04:31 PM | #26 |
Re: Slow leak
