Old 12-26-2011, 10:21 AM   #1
Shadetree
Shadetree's Avatar
Default 1934 Ford 3 Window Coupe
I just found this ad on eBay, remarkable barn find car. The video is on Youtube. He has no reserve on it, but he is safe. What a find! Something we all dream about...
Shadetree
https://www.youtube.com/watch?v=5pOnq...ature=youtu.be
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 12-26-2011, 10:55 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 1934 Ford 3 Window Coupe
WOW that baby,s "SWEEEEEEEEEEEEET"
Cheers KiWi Tony
Old 12-26-2011, 11:33 AM   #3
Russ/40
Russ/40's Avatar
I bet Redneck is getting his wallet out as we speak!
Russ/40 is offline   Reply With Quote
Old 12-26-2011, 11:43 AM   #4
BrianCT
BrianCT's Avatar
Hope the bidders look at both video's and in person.
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
Old 12-26-2011, 02:16 PM   #5
raisinhel
raisinhel's Avatar
somebody is going to get a 'NICE' car and its a DeLuxe to top it off.
i bet hes had 1/2 dozen heavy offers already.
raisinhel is offline   Reply With Quote
Old 12-26-2011, 02:54 PM   #6
David J
David J's Avatar
I have seen 33 std 3w's but I don't recall ever seeing a 34 std 3w . Neat car & it is just rusty & dinged enough that the price shouldn't reach the stratosphere . BUT you never can tell on epay as it is consistently inconsistent at times .
David J is offline   Reply With Quote
Old 12-26-2011, 02:59 PM   #7
deuce lover
deuce lover's Avatar
Its a deluxe.Has cowl lights,ashtray and cigar lighter.Dualtemp accessory also
deuce lover is offline   Reply With Quote
Old 12-26-2011, 04:02 PM   #8
broderchamp
I see that it has a 39 transmission shifter
broderchamp is offline   Reply With Quote
Old 12-26-2011, 04:19 PM   #9
Lawrie
Lawrie's Avatar
Are not all 34 3w delux.Lawrie
Lawrie is offline   Reply With Quote
Old 12-26-2011, 08:07 PM   #10
Barn Junk
Barn Junk's Avatar
Very few 34 3-W standards were made. I have only seen 2, having looked at many dozens of deluxes over the years. I also had, years ago, a set of door window frames that are unique to the 1934 3-W standard.
It's a little strange, 32 3-Ws were all Deluxe, 33 3-Ws were closer to 50/50 Std/deluxe and almost all 34 3-Ws were deluxe. The literature doesn't acknowledge std 34 3-Ws but I am convinced some were assembled but maybe special order.
Barn Junk is offline   Reply With Quote
Old 12-26-2011, 10:14 PM   #11
34ford
34ford's Avatar
all 34 3wd. were deluxe
34ford is offline   Reply With Quote
Old 12-27-2011, 10:51 PM   #12
Digger
Digger's Avatar
I am the current high bidder, and notice the rear and driver garnishes are not there. Anything else you notice missing or questions i should ask?
Digger is offline   Reply With Quote
Old 12-28-2011, 01:17 AM   #13
Barn Junk
Barn Junk's Avatar
Try to get some idea how bad the body sill plates that run along the outside of the frame are rusted. Repros are available but it's a lot of work to replace. I see the quart panels behind the doors are showing rust through and that could mean the sill plates and lower supports for the wood door posts are gone also. Hard to tell until it is taken apart. Such a nice complete car.
Old 12-28-2011, 08:17 AM   #14
jimTN
Strange that the top is open but wood intact. Old material may have wind whipped off during transportation. That is a very solid car.
jimTN is online now   Reply With Quote
Old 12-28-2011, 11:21 AM   #15
Randy
Randy's Avatar
The garnish moulding that is sitting in the front seat in one picture is not for a 3W.
Remember, the rockers and bottoms of the quarters rust because dust and dirt settles in there and then gets wet and retains the moisture in those areas where there is little or no paint protection, mostly bare steel. If the outer sheetmetal is rusted like that, the inner is going to be rusted as well. Rule of thumb for rust, there's always more there than you can see before you start cutting the rust out. The subrails will not survive unscathed when you have rust showing on the outside. They may not be as bad as they are heavier gauge than the outer sheetmetal, but they will have damage as well. They may be pitted or they may be swiss cheese. If they're swiss cheese then the extent of the corrosion damage can include the frame. Obviously, it can be repaired, but how far do you have to go to reach metal that you can weld the patch panels to? You really don't know how big the job will be until you get into it.
Randy is offline   Reply With Quote
Old 12-28-2011, 01:23 PM   #16
FlatheadTed
FlatheadTed's Avatar
Its got a 35 gear shifter a Model A steering wheel, or it could be a 34 heavy truck .damage around the trunk edge and cowl edge, it has later pedal pads covers , fume catcher on the oil filler .37000 miles ?? the rust on the B pillar sills up around the inner fender wells ,looks repairable ,It may have come from a coastal errior
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-28-2011, 01:50 PM   #17
Ball and Chain
Ball and Chain's Avatar
http://youtu.be/PkpDlYkfFaQ
is this the same car not all cleaned up???
Throttle Benders
Est. 1949
Ball and Chain is offline   Reply With Quote
Old 12-28-2011, 06:28 PM   #18
BrianCT
BrianCT's Avatar
Yes
Old 12-28-2011, 07:30 PM   #19
Digger
Digger's Avatar
Ithanks for all the comments, i appreciate it....
Old 12-28-2011, 11:40 PM   #20
33 roadster
Hi, So what is the bid # on ebay I dont see it. Thanks, Larry
33 roadster is offline   Reply With Quote
