Old 12-22-2019, 05:29 PM   #1
3739ford
3739ford's Avatar
Default Chrome repair
Are they a way to repair this chrome piece at home without sending it off.
3739ford is offline   Reply With Quote
Old 12-22-2019, 05:42 PM   #2
TJ
TJ's Avatar
Default Re: Chrome repair
That trim is stainless steel and thin. Unless you can weld stainless it needs to be sent out to a real talented welder.
Old 12-22-2019, 08:12 PM   #3
Kube
Kube's Avatar
TJ is 100% correct. I have repaired worse but again, as TJ had advised, unless you really know your stuff, send it to a professional.
Old 12-22-2019, 08:16 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
It's just trim that can be made nearly invisible with a bit of JBWeld, maybe an extra screw or two, and aluminum furnace tape at home. Unless of course you're fussier than I am. 8^) Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 12-22-2019, 08:16 PM   #5
Newc
Newc's Avatar
Hi; It looks like the door seal retainer at the bottom of a '39 sill.??? I have the pair for a 4 dr rear doors. for sale CHEAPPPP Newc
Old 12-22-2019, 08:35 PM   #6
40cpe
40cpe's Avatar
I thought it is a truck grill.
40cpe is offline   Reply With Quote
Old 12-22-2019, 09:04 PM   #7
FlatheadTed
FlatheadTed's Avatar
39 Grill trim bottom ? ,If it is Remove it and with a 1/2 head carriage bolt in the vice tap it down over that as a anvil so the end s meet nice, drill a couple fresh screw holes underneath ,then get some stainless steel and cut and shape two caps like on the garnish on a 37 to 39 windshield just above the dash .Tap it around a 1/2 bolt in the vice to shape them ,make a hook at the top with a tail on it that you can drill n screw underneath at the bottom .make one for the other side so they match and polish it all ,This is not a professional. repair but might get you out of a hole ,otherwise follow all the good previous advice .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-22-2019, 09:08 PM   #8
3739ford
3739ford's Avatar
It is on top of a 39 pickup grille and very visible. I seen it tonight as I was getting the splash guard down. I would like to try something to tone it down.
Old 12-22-2019, 09:18 PM   #9
FlatheadTed
.can you rotate so the tops down or Might have to be Jacks furnish tape .
Old 12-22-2019, 10:07 PM   #10
itsa52
itsa52's Avatar
I have had excellent results from these guys http://www.microweldamerica.com/
itsa52 is offline   Reply With Quote
Old 12-23-2019, 08:54 AM   #11
Branded
Branded's Avatar
Find a person that is proficient at tig welding thin stainless. This would be easy for a good welder to repair.
Branded is offline   Reply With Quote
