10-05-2014, 10:39 AM | #1 |
33 34 rumble seat compartment question
In the rear bottom below the pivots of the rumble seat there is a pan that goes from left to right with a big half circle indent in the center. It supports the outer panel below the rumble lid. There are 5 "D" cinch nuts to allow the attachment of the trunk panel for the trunk cars.
For those with rumble seats, are these D nuts crimped on the inner side so to be seen? That is, the "D" cinch nut has a thick part with the threads and a detail that goes through the hole that is crimped (smashed) to hold the nut on the hole. I think the crimp part is visible inside the rumble area BUT I have a repo that mounted them on the other side so when assembled the crimped portion is not seen. OR is it done either way by the OEM Thanks for your help!!!! Ed Solari |
10-06-2014, 02:46 AM | #2 |
Re: 33 34 rumble seat compartment question
