Old 05-21-2014, 07:32 PM   #21
Duffy1
Default Re: F150 conversion
F-150 has an aluminum case . Should not be to much heavier than a Model A transmission . I do not have an extra support on my F-150 .
Duffy1 is offline   Reply With Quote
Old 05-21-2014, 08:23 PM   #22
machine girl
it is much heavier, and should be supported (float a motors come with a rear support for a stock A.) Just that it has an alum case means nothing the internals are 3X the mass of a model A trans. that's also why the f150 trans don't fail. we have done over 150 no come backs.( sorry some of those hill climb guys twist u joints. ya you know who you are!)
machine girl is offline   Reply With Quote
Old 05-22-2014, 12:46 PM   #23
bill44
bill44's Avatar
I have been running one for several years that was done by one of our club members. It is great. I have a 29% 4th gear, but they have 4 different ratios all the way down to 21%. It doesn't climb very well, and you need to be going at least 45 to keep it from lugging.
bill44 is offline   Reply With Quote
Old 05-22-2014, 02:05 PM   #24
machine girl
yes, we will not sell a 29% only the 22%or 28% or as ford calls them41.1%(no good) 26.7% or 37.9%.
Old 05-26-2014, 02:46 PM   #25
MurphyJ
For what it is worth:
When i did my f150 conversion i weighed the f150 transmission (71 lbs)
and then the stock 1930 model a transmission (38 lbs) and figured the 33 pound difference was not a major concern as i also reduced the flywheel weight by 20 pounds. So far, and 2500 miles, i have yet to experience a problem. I certainly would add the additional support if it is warranted.
MurphyJ is offline   Reply With Quote
Old 05-26-2014, 09:05 PM   #26
AL in NY
AL in NY's Avatar
I agree with MurphyJ. 33 pounds doesn't warrant an extra support. I did my own F150 conversion and five thousand miles and NO problems. My engine crank handle stills fits through and engages the crank.
AL in NY
AL in NY is offline   Reply With Quote
