Old 06-13-2022, 08:29 PM   #1
Barnwood
Default Problem with adjusting arm and trunion and clutch pedal
On the clutch pedal, one side of the "ring" is thinner than the other. When I place the adjusting arm and trunion inside, there is a gap. How can I fix this?
Thank you.
Barnwood is offline   Reply With Quote
Old 06-13-2022, 09:36 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Problem with adjusting arm and trunion and clutch pedal
That is many years of wear. You can bush it, build it up and machine, or replace it. It might go another bunch of years without trouble, and shouldn't cause a rattle since it is under tension.
Old 06-13-2022, 09:47 PM   #3
GRutter
GRutter's Avatar
That area is subject to break, leaving you without the ability to disengage the clutch.
Check the clutch release shaft arm also. In the interim, look for a replacement clutch pedal. I don't believe they have ever been reproduced so check with Berts
GRutter is offline   Reply With Quote
Old 06-14-2022, 09:37 AM   #4
nkaminar
nkaminar's Avatar
A restoration would be to weld it up and re machine it. If you can find a good replacement that is a lot easier.
Old 06-14-2022, 09:31 PM   #5
Brentwood Bob
Pm sent.
Guess you can't receive pm(private messages) yet.
I have both early and late OEM pedals.
Brentwood Bob is offline   Reply With Quote
Old 06-15-2022, 11:52 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
That is something we repair quite often. Here is some measurements taken from the original A-7520 print...
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-28-2022, 07:21 PM   #7
Barnwood
Does anyone know how I can find places that may repair this?
Old 06-28-2022, 07:36 PM   #8
nkaminar
nkaminar's Avatar
Send it to Brent. Brent's address is:
260 Rocky Branch Rd.
Elizabethton, TN 37643
Old 06-29-2022, 11:54 AM   #9
JayJay
This is a simple repair that any good machine shop should be able to do with Brent's drawing. I have this same issue with my clutch pedal and will repair it myself (when I disassemble the car) by adding weld material to the hole, then boring and reaming.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is online now   Reply With Quote
