Old 05-23-2022, 01:13 PM   #1
Gary57210
Gary57210's Avatar
Default Noisy transmission
How noisy are the straight cut gears in a Model A transmission? Our second gear sounds terrible.
Gary57210 is offline   Reply With Quote
Old 05-23-2022, 03:52 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Noisy transmission
Straight cut gears will have the whine associated with them in low and second gear. In high gear the main shaft dogs onto the input shaft for 1:1 drive so it doesn't whine with gear noise. Now if the noise isn't a normal gear whine in low or second gears then there may be some other problem with the gears or bearings that rotate while in those gears.
Old 05-23-2022, 04:42 PM   #3
ursus
The second gear is the hardest working gear in the box and most likely to wear out first. You can remove the shift lever assembly and evaluate the condition of the gears.
Old 05-23-2022, 06:25 PM   #4
LeonardS
Did you check the gear oil level in the transmission?
LeonardS is online now   Reply With Quote
Old 05-24-2022, 07:50 AM   #5
bavArian
bavArian's Avatar
The 2nd gear pair on my A is louder than 1st and 3rd as well.
As stated, check the oil first.
As long as it's "just" a whine I would continue to drive it. You should notice if it gets worse. When the noise changes I would start to investigate.
bavArian is offline   Reply With Quote
Old 05-24-2022, 10:02 AM   #6
katy
katy's Avatar
It's called a musical transmission, the old Chevs were bad for that.
Old 05-24-2022, 10:42 AM   #7
Sunny the Model A
Sunny the Model A's Avatar
Model A's love to whine, mine does, fresh 600w is what I use, and it shifts nice and smooth now that I rebuilt the shift tower. if it whines, don't lose sleep about it, it's normal. All cars of that era made the same sound, be it a Duesenberg, a Cadillac V16, or a Ford Model A. but if it gets so loud the neighbors notice, then look into it.
"Quality means doing it right when no one is looking" Henry Ford
Sunny the Model A is offline   Reply With Quote
Old 05-24-2022, 11:39 AM   #8
Gary57210
Gary57210's Avatar
I've checked the oil and it's OK. Mine has more of a growl than a whine. I'm getting another transmission to go through and then I can just change it out.
Old 05-24-2022, 01:39 PM   #9
jack backer
What to look at is the tops of the gear teeth and the face of the tooth for pitting. The tooth top tells the story, this transmission is used but still serviceable, it has clash wear but the top of the tooth isn’t tapered or ‘sharpened’
File Type: jpg E721982C-641E-49A2-AE81-73318625DEF8.jpg (44.0 KB, 71 views)
jack backer is offline   Reply With Quote
Old 05-24-2022, 06:04 PM   #10
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Mine is noisy in second on deacceleration, but quiet on acceleration.
Old 05-24-2022, 06:23 PM   #11
1crosscut
1crosscut's Avatar
I would venture that one of the cluster gear bearings has gone bad.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-25-2022, 12:35 AM   #12
al's28/33
al's28/33's Avatar
crosscut nailed it, I just had that problem resolved. Bad bearing and worn cluster gears was my issue, better trace the problem before the whole thing jams up and you get stuck.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
