Old 07-09-2020, 02:06 PM   #21
Kube
Kube's Avatar
Default Re: Pressure plate finger adj
Originally Posted by Jack Shaft View Post
When you clutch disc wears that dimension changes.So no my point is all fingers need to be the same height,so the pressure plate springs are compressed evenly by the throw out bearing.
When the plate and disc are new, all three fingers need to be the same - in this case, .750".
And yes, as the disc wears, that dimension will change but should stay fairly even with one another.
Old 07-09-2020, 03:48 PM   #22
FlatheadTed
FlatheadTed's Avatar
This is the proper rig for setting clutches ,My supplier insisted that unless my fly wheel was faced he could not offer a solution for the jumpy clutch he supplied. I pulled the clutch out and set it up on the jig ,yes one finger was low ,took the jig back to show him ,Woopty doo . I wouldn't trust any one without checking .you could maybe use the diaphragm one ,and a vernier .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
