Old 08-01-2012, 08:38 PM   #1
34hardhead
34hardhead's Avatar
Default is this a 1934 V-8 Ford marine radiator
I pulled this out of the barn to ask my dad what it is, he said that he picked it up at Hershey, 40 years ago. He thinks it came off an old boat, but looks like it will fit a 1934 engine, maybe off of an old engine stand?
anyone know what it really is?
34hardhead is offline   Reply With Quote
Old 08-01-2012, 09:00 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: is this a 1934 V-8 Ford marine radiator
A henway??
Old 08-01-2012, 09:29 PM   #3
Gary in La.
Gary in La.'s Avatar
Fancy minimal cooling system for an early drag racing car? Pretty neat looking item.
Gary in La. is offline   Reply With Quote
Old 08-01-2012, 09:36 PM   #4
Jason in TX
Jason in TX's Avatar
Very cool!
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 08-01-2012, 10:10 PM   #5
DavidG
DavidG's Avatar
Those are '36 water inlet/motor mount brackets.
Old 08-01-2012, 11:57 PM   #6
FlatheadTed
FlatheadTed's Avatar
It looks like a heat exchanger ,Its got a top tank for the fresh water with pipes to take the rubber hose onto the 21 stud pumps .Moter mounts on the bottom ,and inlets ether side for the salt water .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-02-2012, 10:30 AM   #7
G.M.
I think Ted is correct. It looks like a heat exchanger to me. For those not familar the fresh water engine coolant is circulated through the large pipes and a separate pump runs sea water around the tubes of fresh water through the small pipe threaded holes at either end of the top tank or "heat exchanger" G.M.
www.fordcollector.com
