04-24-2021, 04:05 PM | #1 |
Engine block cleaning question
I am working on a '31 coupe with a friend. Discovered today the radiator has grease in it from the water pump bearing. It failed the in car radiator flow test even though it took the full 1 1/2 gallons to fill it. Next is to get the radiator out and to the repair shop to find out exactly how bad it is plugged. If it's really bad and I decide to remove the head for cleaning as well, what do I soak the water jackets in the block with? I want it clean as possible before I replace the water pump with a Rupert's.
04-24-2021, 05:37 PM | #2 |
Re: Engine block cleaning question
Greasy cooling systems are the result of improper greasing of the rear water pump bearing. I have a friend who used a handful of laundry powder to clear it but he found that caused too much foam. Foam doesn't do a good job of cooling so we looked for a grease cutting detergent that doesn't foam. We settled on dish washer tablets. A couple of those in the top of the radiator, go for a drive (more than to the ice cream shop) and drain while still hot and the greasiness was nearly gone. A repeat and all was good.
That costs next to nothing and might solve your problem without taking anything apart.
04-24-2021, 06:23 PM | #3 |
Another vote for use of dishwasher tabs to de-grease.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
04-24-2021, 10:22 PM | #4 |
I would not remove the head or the radiator.
I like to use Metal Kleener 2014 (that is made by Rust 911) to remove all the old grease and oil from the cooling system. This stuff is concentrated and bio-degradable). I fill the cooling system with the solution and drive around for a few days, drain and flush the system. It will be free of grease and oil. If the cooling system also has a lot of rust, then use Rust 911. Mix according to instructions and fill the cooling system and again drive around a bit. you may have to leave it in for several days, up to a week. Drain and flush. It may take 2-3 applications of Rust 911 to get all the rust out but your cooling system will eventually come clean and rust free. These products will not harm the radiator, hoses or gaskets and are bio-degradable and come in concentrated form. They will not harm the paint BUT I recommend you immediately flush with water if you do get some of the solution on the paint. I have also used Metal Kleener 2014 with very good results to clean all the old varnish and crud from gas tanks without removing the tank from the car. You can follow up with Rust 911 if there also is a lot of rust in the tank. I buy directly from "rust911.com" This is my experience and my opinion. Chris W. Last edited by CWPASADENA; 04-24-2021 at 10:26 PM. Reason: CLARIFICATION |
04-24-2021, 11:02 PM | #5 |
Check out this range of products. http://liquidintelligence.com.au/pro...m-cleaning-kit
I've seen it used and WOW! that stuff works. Note the prices are Australian dollars. You guys can reduce them by about 25%
04-25-2021, 09:34 AM | #6 |
04-25-2021, 04:19 PM | #7 |
Has anyone considered whether a small amount of "greasiness" in the radiator might actually be a good thing? I occasionally screw in the grease cup on the rear water pump bearing (it contains special water pump grease) and also add a cup-full of neats-foot oil into the water. I have never added any of that special green (and expensive) radiator coolant, and yet even after 30 years there is no rust in my my radiator water. The radiator works well too - never any cooling issues.
04-25-2021, 05:06 PM | #8 |
I have cleaned numerous cooling systems using dishwasher soap. Drain existing fluids, fill with water and a good dose of liquid dishwasher soap. Run 15 minutes with engine at operating temp. Drain. Repeat. Then drain and flush with clean water while engine is running. She'll come out spotless.
04-25-2021, 05:16 PM | #9 |
If there is a coating of "greasiness" on the inside of the radiator and water jacket the radiator can not dissipate the heat. On this particular car, a well meaning mechanic pumped the zerts full of grease, and not the special water pump type either. Do you normally run the green anti-freeze down under? Does it ever freeze down there?
04-25-2021, 05:22 PM | #10 |
Thanks Oldgearz - I really don't want to remove the radiator. Does the liquid work better than the granular, or is it just what the navigator has on hand under the kitchen sink? What?
04-25-2021, 05:32 PM | #11 |
The navigator just pulled out from under the sink a big ol tub of Cascade complete. It has Dawn grease fighting power with lemon scent! Could be a win - win if it covers up the smell of raw gas!
04-25-2021, 05:46 PM | #12 |
Cascade with Dawn will work, but I believe Dawn Dish Soap by itself is the best for cutting grease.
David Serrano |
04-25-2021, 06:53 PM | #13 | |
BTW, Special water pump grease is actually a low melting point wax. I mix in some powdered graphite so better lubrication and it stays put. It will not affect the cooling system either if some does get in there.
