Old 03-02-2021, 02:16 PM   #1
Roger V
Roger V's Avatar
Default Y-Block Spark Plug Wire Grommets
Is it difficult to get the wires through the grommet holes? Seems I've read about difficulties. Any tricks or just slides through easily?
Roger V is offline   Reply With Quote
Old 03-02-2021, 02:51 PM   #2
Ole Don
Ole Don's Avatar
Default Re: Y-Block Spark Plug Wire Grommets
I used wires from Speedway, and grommets from MACS. I peeled the grommets around the wires, they do not slide together. Then assemble the metal parts around the grommets when the wire lengths are correct. They are a bit of a bitch to do, but good parts last a really long time and are worth the effort.
Ole Don is offline   Reply With Quote
Old 03-02-2021, 02:54 PM   #3
Dobie Gillis
Dobie Gillis's Avatar
It can be a little bit of a struggle. Suggest you slather 'em up with spray silicone lube to help 'em slip through. A pair of 90* needle nose pliers can be your friend but be careful not to pull on the terminals.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 03-03-2021, 07:45 PM   #4
Gene F
Gene F's Avatar
I think mine came with slit in them, and then I put the brackets around em'''
Old 03-04-2021, 10:07 AM   #5
54vicky
54vicky's Avatar
I agree with gene going from memory
54vicky is offline   Reply With Quote
