Old 02-26-2015, 11:28 PM   #61
Gold Digger
Default Re: Do you carry a fire extinguisher?
Besides a fire extinguisher and tools I make sure my cell phone is charged and in my pocket.
Gold Digger is offline   Reply With Quote
Old 02-26-2015, 11:32 PM   #62
marc silva
marc silva's Avatar
I carry a halon so you can still eat your steak after if it catches fire. Leaves no residue whatsoever. Don't forget a first aid kit. I like to get burned a lot..something about tender skin and hot manifolds. They just go together.
marc silva is offline   Reply With Quote
Old 02-27-2015, 07:45 AM   #63
EJGjr
IT is a good idea.I do and had to use it when the condenser quit and the motor backfired. Thats all it takes.I forgot the marshmellows.
EJGjr is offline   Reply With Quote
Old 02-27-2015, 07:52 AM   #64
al's28/33
al's28/33's Avatar
I keep mine in the trunk but my pickup has an antique version mounted inside the cab for looks.....
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-27-2015, 08:25 AM   #65
barkleydave
barkleydave's Avatar
keep two in the wood storage box I built for my CCPU That way easy to get to and you are already out of the vehicle so if it goes real bad at least you are not in it!
barkleydave is offline   Reply With Quote
Old 02-27-2015, 09:03 AM   #66
gpits68
gpits68's Avatar
I think a fire extinguisher is a must . Along with spare parts and tools , I keep a tow strap handy in case someone breaks down and are still in the road . My fire extinguisher is on passenger side in front of seat .
gpits68 is offline   Reply With Quote
Old 02-27-2015, 11:54 AM   #67
brum1
brum1's Avatar
yes
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 02-27-2015, 05:04 PM   #68
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
YES!! It is a Kiddie fire extinguisher, #A38663463, and uses a dry chemical agent. It is designated for automotive fires both gasoline and electrical. It cost about $20. I mounted it on a side brace used for the cardboard side liner in my coupe's trunk. It comes with a mounting bracket. Would not be without one. Remember to replace it every few years as it has a shelf life.
Dick M is offline   Reply With Quote
Old 03-05-2015, 10:57 PM   #69
kevinwalshe
A gallon of water, for you or the radiator.
kevinwalshe is offline   Reply With Quote
Old 03-06-2015, 11:54 AM   #70
partridgekelley
I do now!! I had just put together a 29 Tudor and just drove about 100 yards from home when a fuel psi. regulator leaked and caught fire. I was lucky that my neighbor had an extinguisher , she ran down the hill to my car and got it out before it did too much damage. What a mess to clean up. Beware of the round fuel regulators made by Cal-Custom, I took them off my other cars and added fire extinguishers to all my A's , and the kitchen & garage. That's my 2 cents worth!
partridgekelley is offline   Reply With Quote
Old 03-06-2015, 02:00 PM   #71
mshmodela
mshmodela's Avatar
Going to say another tip from the experts here I do it run the fuel out of the carb:
https://www.youtube.com/watch?v=Uz_Es5xz0r4
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-06-2015, 09:51 PM   #72
Tom Wesenberg
Tom Wesenberg's Avatar
I just got an email today that warns about fuel pressure regulators leaking gas due to ethanol eating them up. I forwarded it to several friends. I don't use a pressure regulator on my Studebaker. I cut the pressure and flow to the correct amount by using a resistor to drop the voltage to the electric pump to 2.7 voltss. This costs much less, is safer, and has the added benefit of using less power.
Old 03-06-2015, 10:05 PM   #73
Bill in SoCal
Bill in SoCal's Avatar
Yes!
Bill in SoCal is offline   Reply With Quote
Old 03-07-2015, 11:55 AM   #74
rocket1
I have been carrying one for at least 40 years,never used it,but remember you might need it to help someone else!
rocket1 is offline   Reply With Quote
Old 03-07-2015, 12:01 PM   #75
Jeff/Illinois
Jeff/Illinois's Avatar
Originally Posted by johnbuckley View Post
perhaps a bit late in this case....
YOWSA that A's toast for sure. Nothing left to rebuild. Wonder what sparked that?? Shorted terminal box? I'd love to know...............
Old 03-07-2015, 08:18 PM   #76
cedar
yes i do.
cedar is offline   Reply With Quote
