07-11-2020, 10:38 PM | #1 |
Valve guide tool help needed
Could someone please give the the rough dimensions of a valve guide removal tool like the one below
I cant find mine so i am going to try and spin one up on my lathe. Thanks Brendan |
07-12-2020, 08:05 AM | #2 |
Re: Valve guide tool help needed
2 13/16" overall length. 1 9/16" narrow shank. 5/8" thick part before taper.
Diameters: 5/8" narrow shank. 3/4" thick shank before taper. 1 3/16" at the top of the flare (bell). The inside of the taper is hollowed out to match the taper of the valve. I'm no machinist, and this is as close as I can measure. After doing the lengths and diameters, you will need to somehow hollow out the middle, so that the tool will wrap around the valve stem for removal of the guides. |
07-12-2020, 07:02 PM | #3 |
Thanks Mike
Very helpful Brendan |
07-12-2020, 08:18 PM | #4 |
Success
Thanks to Mike Peters help |
07-12-2020, 11:35 PM | #5 |
Well I'm impressed with both of you...........
Brendan, nice job cutting that tool, I am so jealous |
07-13-2020, 12:39 PM | #6 |
07-13-2020, 07:22 PM | #7 | |
Your wife is right, life as home mechanic was a lot harder before these forums came along. My milling machine is just a Mill Drill, I have just enough equipment to get by. Brendan |
