Old 04-10-2017, 10:47 AM   #1
bengt
bengt's Avatar
Default rear bumper is not level
In order to make the rear bumper level, I need to put a wood block where the bracket is bolted to the frame. What is wrong?
bengt is offline   Reply With Quote
Old 04-10-2017, 11:19 AM   #2
denniskliesen
denniskliesen's Avatar
Default Re: rear bumper is not level
Did you check the 3/8" bolts that bolt to the top of the crossmember? You have 3 locations where the bracket bolts on. You shouldn't need to block or shim to get the correct bumper height. Most likely you have a bent bracket?
denniskliesen is offline   Reply With Quote
Old 04-10-2017, 12:18 PM   #3
Big hammer
Maybe your level isn't right? It happens!
Old 04-10-2017, 12:47 PM   #4
jw hash
jw hash's Avatar
your rear bumper iron should perpendicular with the frame. so if your frame is not level the bumper irons will be off to. that being said, you either you have the wrong irons and or they are bent.
jw hash is offline   Reply With Quote
Old 04-10-2017, 01:15 PM   #5
bengt
bengt's Avatar
Thanks all of you for your ideas.
Dennis: yes the bolts to the cross member are in one of the photos. I can't see anything wrong with them.
Bent bracket, that's my thought too, but how can it be bent, it's flatter the other way. If the bracket has had an accident and become bent, it should be bent "sideways" not "up/downwise"
Big Hammer: The level is right.
JW: I don't understand
Old 04-10-2017, 01:48 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
My Right Leg is shorter, so I can't be of much HELP to you---LOL
I'm wearing the appropriate "T" shirt, "ROCK & ROLL WILL NEVER DIE"!
Bill Wobble
"THE ASSISTANT GURU OF STUFF"
Old 04-10-2017, 02:28 PM   #7
ronn
I fix mine with a sledge hammer.......................!
works like a charm
