08-29-2012, 12:47 AM | #21 |
Re: A couple of Model A questions
I had a medical issue that prevented me from working on the car, but I finally got back around to working on the car but had a few issues and more questions.
When I poured gas in the tank, luckily I only put in about 1/4 gallon, fuel started leaking out the carb. It's a Tillotson model X, has anyone used the rebuild kit from Little Dearborn? I ordered books through them, but I haven't ordered any parts. Also, when I installed the battery, the tail light comes on and won't shut off no matter what position I have the key at. I can use the key to crank the engine so I'm thinking it's not the ignition switch. Anyone have any ideas? |
08-29-2012, 05:57 AM | #22 | |
08-29-2012, 06:00 AM | #23 |
The key is wired ORIGINALLY to just connect the coil to the points, and should have nothing to do with operating the starter. On the Model A all circuits are always "hot" (have 6 volts available). Your brake pedal may not be returning to the full OFF position, or the switch may be shorted and keeping the brake light on.
The carb kit is probably the same kit from each vendor and should be fine for the carb rebuild. The gas leaking from the carb is most likely a stuck needle and seat from setting unused for so long. Ethanol in the gas greatly increases such problems. The gas valve under the tank can be turned off to stop the flow. For the gas to flow to the carb the gas tank valve handle should point up and down, as horizontal is OFF. Last edited by Tom Wesenberg; 08-29-2012 at 06:27 AM. |
08-29-2012, 08:05 AM | #24 |
Is the light switch on the steering wheel in the parking light position? The lights are not controlled by the ignition switch.
08-29-2012, 08:22 AM | #25 |
When you said the taillight comes on, I was thinking brake light. If it is the taillight, then the parking or headlights should also be on, unless some wiring is messed up.
08-30-2012, 09:50 AM | #26 |
you need a mentor to guide you through this, either another FordBarner or a local club guy. will save you LOTS of time and money, i.e. fewer wild goose chases and unneeded parts purchases..........
our next Model A is out there in the unknown...... |
08-25-2013, 10:48 PM | #27 |
What is the serial # on the left side of the engine block?
I would buy some wiring harnesses if the existing sets look "shaggy". The color coding will help you understand the wiring diagrams you obtain. |
08-25-2013, 11:19 PM | #28 |
Add an owners manual to your list of books to buy.
08-26-2013, 10:23 AM | #29 |
I have to agree with the recommendations to obtain the Les Andrews books. They have a wealth of information and are easy to understand.
It would be well worth your time to go over the vehicle and make sure all of the fasteners are snug. After my father passed I acquired the tudor he was restoring. I've found more than one fastener that I'm sure he was going to get back to, but somehow over looked. I also agree with the recommendations to put some miles on it! You have a great vehicle to start with and should enjoy it. |
08-26-2013, 06:30 PM | #30 |
Whoa thread revival here! Notice the OP hasn't posted in over a year?? I see jefferzbooboo and BetsyModelA (poster in another thread) both live in ND and are only a couple hours apart, I hope maybe they could collaborate on their issues? I wonder how the OP came out with getting his A going and why he hasn't been back?
Aaron in Tacoma (although still a Montana hillbilly at heart ) |
08-26-2013, 08:26 PM | #31 |
Les Andrews Model A Mechanics Handbook
08-26-2013, 10:55 PM | #32 | |
02-01-2014, 12:24 PM | #33 |
If this car hasn't been running in 7 years, please take extra care with it, it doesn't take much to change a really good engine into a boat anchor. Drain the oil and check it for water and sludge before even turning it over. Drain some water from the petcock on the bottom radiator hose and check it, hopefully there is water and antifreeze, if nothing is there the story could be good or bad.
If all looks good, pull the plugs and put a few drops of oil down the holes and turn it over without the plugs in it, to see if there is any problems of a ring sticking due to moisture in a cylinder, and do this by hand. If the engine is frozen, don't panic because there are other things you can try. Next is the battery and its connections, a seven year or older battery is going to give you trouble, save yourself some headache and just get a fresh one. Check and clean all the connections and you will eliminate most of the gremlins. If you have new oil, the engine turns over by hand with no problems and you have replaced and checked the fuel you will only have to put a drop of oil in the distributor oiler before the engine is ready to try. I would look at that choke rod assembly also, judging by the pictures. Good luck, it is a beautiful car, and by the way you have stumbled onto the greatest wealth of knowledge I know of here at ford barn. A good club is great for hands on help and social reinforcement, but for direction, points of view and overall knowlage, this site is unmatched. Please keep in mind that my list might not be complete, so keep reading and studying for yourself. |
02-02-2014, 12:36 AM | #34 |
On the distributor oiler I would fill it until it's ready to overflow. You can't overoil it.
If you have an aftermarket shaft with a hole in the top for oil, then you can overoil that one where the extra spilled oil can flow onto the cam and get into the points contacts. |
02-02-2014, 02:05 AM | #35 |
5/26/12 was the last post from this guy. Either he got it running and has no more questions or he no longer has it.
02-02-2014, 07:57 AM | #36 | |
