Old 07-31-2020, 03:25 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default Exhaust pipe question/opinion
Working on a customers 28' Roadster Pick up. When we reinstalled the muffler/tail pipe to the exhaust manifold, I noticed the section of the stainless pipe was very deep to bright blue from the manifold to the muffler section.
Is the owner running it too lean causing the pipe to heat badly???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 07-31-2020, 04:02 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Exhaust pipe question/opinion
Or the timing is real late.
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1 worth.
https://www.youtube.com/watch?v=51ufACHJMfU
Old 07-31-2020, 08:13 PM   #3
Gary WA
Gary WA's Avatar
That one is hot!!
www.whidbeymodelaclub.com
Old 08-01-2020, 09:56 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
I agree that the timing is probably a bit retarded . When the timing pin meets the dimple in the cam gear I adjust the distributor cam so that the TRAILING end of the rotor tip points exactly at the number one contact in the distributor cap body with NO clockwise backlash . Points gap also has an effect on timing because the spark happens just as the points begin to open . More gap will cause the points to open quicker . Factory specs for points gap is anywhere from eighteen to twenty two thousands . I set my points anywhere from twenty to twenty two thousands . The wider gap gives better throttle response . The smaller gap of eighteen thousands is right on the edge of being retarded and will soon need readjustment . If the timing is slightly retarded it will cause the engine to run hotter and have less power . The more retarded the hotter the exhaust system will get untill it gets red hot , not a good situation !!!
Old 08-01-2020, 10:16 AM   #5
Purdy Swoft
On the other hand , lean operation will also cause overheating . Factory specs for GAV adjustment is one quarter turn open on the GAV knob after a brief warm up on a cold engine . If the larger model B carburetor is used the GAV should run completely closed after warm up . Both timing and GAV adjustment have an effect on running temps .
Old 08-01-2020, 10:24 AM   #6
Jack Shaft
plugged muffler
Jack Shaft is offline   Reply With Quote
Old 08-01-2020, 10:25 AM   #7
Jack Shaft
he's good,he has a heat shield..
Old 08-01-2020, 10:30 AM   #8
Benson
Benson's Avatar
What is the paint code for that color of paint?
Benson is offline   Reply With Quote
Old 08-01-2020, 11:51 AM   #9
Big hammer
Smoking hot cherry red !
get a bigger hammer tap done
Old 08-01-2020, 09:22 PM   #10
warhorseracing
warhorseracing's Avatar
That kind of heat will definitely warp the manifold.
warhorseracing is offline   Reply With Quote
Thread Tools
Display Modes
