07-14-2020, 12:06 PM | #1 |
Head Torque Question
In Bratton's catalog, it specifies that the torque on a 5.5 to 1 ratio head should be 65lbs. I have been told to torque to 55 lbs.
Can anyone advise the correct torque for the head nuts on a 5.5 to 1 head???
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 01-24-2022 at 09:39 PM. |
07-14-2020, 01:15 PM | #2 |
Re: Head Torque Question
I have always used 55 ft/lbs with no problems. Routinely check mine. Snyder's recommends 55 ft/lb.
Add; I have a 5.5 head.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 07-14-2020 at 07:51 PM. Reason: Add verbage. |
07-14-2020, 01:58 PM | #3 |
My engine builder said to torque my 6.0 head 55 ft-lbs initially and re-torque 60 ft-lbs
07-14-2020, 04:35 PM | #4 |
I have heard many different tales of woe here.
Truth is that both 55 and 65 Ft# are correct. 55 ft# for clean lubricated fastener, 65ft# for dry assembly. J
As Carroll Smith wrote; All Failures are Human in Origin. |
07-14-2020, 06:35 PM | #5 |
I think the Ford factory specification was "Good and tight". Maybe "real tight" on a standard head and "Good and tight" on the police heads.
07-14-2020, 06:52 PM | #6 |
ADDED: Have used Copper Coat and Victor or Best gaskets. There is no need for 65 ft lbs ... this only distorts the upper deck of block and might strip out weak stud threads. Just saying.... Last edited by Benson; 07-15-2020 at 07:55 AM. |
07-14-2020, 09:32 PM | #7 |
I always use a sealer with the head gasket so I opt for the lower setting. 55 ftlb is all I have ever used and I've only ever blown one gasket but wasn't head tension that caused that one.
07-15-2020, 05:08 AM | #8 |
909, please, what sealer did you use for the very hot head sealing?
Thanks!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
07-15-2020, 05:32 AM | #9 |
[QUOTE=Werner;1909240]909, please, what sealer did you use for the very hot head sealing?
Thanks![/QUOTE Werner, I have used Hylomar but I now have ABRO Copper Gasket Spray. It is an American product. There are several on the market and I'm sure there will be one available in Germany.
