Old 06-21-2020, 04:32 PM   #1
31 ford
Default Will turn over but won't start
A friend has a 31 Model A that has spark all the way to the points but the spark stops there. There is no spark leaving from there to the plug connectors ,therfeore ,no spark to spark plugs ! Help please ! ! THANK YOU
31 ford is offline   Reply With Quote
Old 06-21-2020, 04:51 PM   #2
Bob C
Default Re: Will turn over but won't start
If you hold the coil wire 1/4" from the head and open the points do you get a spark at the coil wire?
Old 06-21-2020, 04:51 PM   #3
Jim/GA
Jim/GA's Avatar
Push the wire up into the nose of the coil. Se if it will go in more. They sometimes work loose and do not connect.
If it still won't start, take the other end of that wire out of the top of the distributor and hold it about 1/8" from a head nut while someone cranks the engine with the key on. You should see a spark there.
If you see a spark there, inspect the rotor. IS the little black flat spring piece in place?
With #1 cylinder at TDC (use timing in) where does rotor point to inside the distributor body?
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 06-21-2020, 05:09 PM   #4
1955cj5
1955cj5's Avatar
You might also clean the point contacts themselves. Sometimes they corrode if it's been sitting for a while.
I need to clean mine every spring.
Use a tungsten point file or sandpaper.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 06-21-2020, 07:06 PM   #5
chrs1961815
chrs1961815's Avatar
I would say it is probably the points. To clean the points, use a point file or emery paper because it does not leave magnetic particles unlike regular sandpaper.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-21-2020, 08:36 PM   #6
31 ford
Thank you for your suggestions. Yes, removed coil wire from distributor and place near head and have strong spark. Have 6 volts at red wire on positive terminal (passenger side). With key on, manually open points and do have spark at points .
Problem is there is no power from spark plug connectors to plugs.
I don't understand why -except- could it be the wire connecting the lower plate to upper plate in distributor ?
Old 06-21-2020, 08:52 PM   #7
Bob C
Could be the rotor is shorting to the distributor shaft.
Old 06-21-2020, 09:07 PM   #8
Big hammer
I was fiddling with my A, it would turn over but no start. I found I had laid the rotor down in a dark spot, placed the rotor back in place, I then went for A nice ride.
get a bigger hammer tap done
Old 06-21-2020, 09:53 PM   #9
1955cj5
1955cj5's Avatar
Did you pull a sparkplug?
Was it wet or dry?
Could it just be severely flooded?
Old 06-22-2020, 12:42 AM   #10
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If you use a screwdriver from a head nut to a quarter inch off of one of the distributor nubs for the plug wire, do you get a spark? Is your timing set correctly?
Old 06-22-2020, 06:08 AM   #11
chrs1961815
The lower plate wire could possibly be shorting out against the side of the housing if not installed correctly. It is also possible that the lower plate lug is bent and shorting against the housing from the ignition cable being screwed in too far.
Old 06-22-2020, 06:38 AM   #12
Jim/GA
Jim/GA's Avatar
Bad rotor or timing is WAY off, so that the rotor tab is not even close to the pin inside the distributor body that it is supposed to fire to.
Jim Cannon
Old 06-22-2020, 07:47 AM   #13
1931 flamingo
1931 flamingo's Avatar
Even if timing was way off it should still "spark".
Paul in CT
Old 06-22-2020, 08:29 AM   #14
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I just ran into a crazy one. All was good with distributor housing and cap off. With the cap on, no spark. With the cap off, we then pushed down on the ball of the upper plate and things shorted out. When the housing was held in place, it pushed the upper plate down and that caused the problem. Have not had a chance to see what was shorting out, but it was tough to find.
Jacksonlll is offline   Reply With Quote
Old 06-22-2020, 10:18 AM   #15
30 Closed Cab PU
[QUOTE=31 ford;1901599]Thank you for your suggestions. Yes, removed coil wire from distributor and place near head and have strong spark.
This seems to indicate the ignition is working.
A further test is to take a spark plug lead off a spark plug and space it about 1/8 inch from the plug terminal. Ignition on, use the starter rod to turn over the motor and see if the gap sparks. If yes next step. This indicates the spark plug has spark.
With the timing pin locating TDC cylinder 1, is the rotor pointing correctly at cylinder 1? If not familiar with proper rotor position take and post a picture here of the Distributor with the Distributor cap removed.
If yes then adjust the distributor cam so the points just open on one of the 4 distributor cam lobes.
This does not include gaping the points, but can repeat including gaping the points once it is running.
30 Closed Cab PU is offline   Reply With Quote
Old 06-22-2020, 10:24 AM   #16
30 Closed Cab PU
If no spark at the plugs above, also check that the Cap springs up slightly before clamping it down with the distributor straps. If not, the contact on the rotor may need to be sprung up so it contacts the button contact on the distributor cap, also inspect the button contact on the cap to insure it is good/OK.
Old 06-22-2020, 10:32 AM   #17
30 Closed Cab PU
Hi Jackson,
Had something not exactly the same, but similar. Previously someone had installed the wire between the plates incorrectly. The lug was installed and bent over incorrectly and occasionally the wire shorted. Hope this is helpful.
Old 06-22-2020, 12:02 PM   #18
Jeff/Illinois
Jeff/Illinois's Avatar
Also I assume that when you take the distributor cap off, you see the rotor turning while somebody cranks the engine. If not you probably have a bad timing gear. Elementary but good idea to check.
Jeff/Illinois is offline   Reply With Quote
Old 06-22-2020, 07:14 PM   #19
31 ford
Thank you all for your suggestions on trouble shooting this starting problem. Will try them all by the end of week and will then give "status update" . Thank you for the help.
Old 06-23-2020, 08:47 AM   #20
Marshall V. Daut
Check your private messages in the top right corner of this webpage.
Marshall
