Old 03-24-2020, 06:34 PM   #1
jack wingard
Default Manifolds
Suggestions (before I break the bolts) on tips on how to separate the intake from the exhaust manifold. Thanks in advance.
jack wingard is offline   Reply With Quote
Old 03-24-2020, 06:45 PM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: Manifolds
Are you installing a new exhaust manifold? If not, I would leave them together. Mine broke off when I had to replace the exhaust but then it doesn't matter as the new one is tapped for new bolts.
Sunnybrook Farm is offline   Reply With Quote
Old 03-24-2020, 06:52 PM   #3
chrs1961815
chrs1961815's Avatar
The exhaust manifold threaded holes are blind - meaning that they cannot be accessed from the inside. I have broken off several and I have found that the heat method is the best way, the same as used to take out head studs. With a torch, heat the bolts up and spray penetrating oil after. Try again, but be careful. If they don't budge a tad, more heat. Repeat until it loosens up enough. You will not hurt anything with the heat. Also, don't drop the assembly, they have been known to break after that.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 03-24-2020, 07:04 PM   #4
jack wingard
that sounds like a good starting point. has anyone ever cut the hex head off and start from that point?
Old 03-24-2020, 07:33 PM   #5
Brentwood Bob
Tricky to drill out the shaft of the bolts without going too deep, or going off center. The blister inside the exhaust manifold is fragile.
Brentwood Bob is offline   Reply With Quote
Old 03-24-2020, 08:55 PM   #6
chrs1961815
On an exhaust manifold I broke off, a friend of mine who does engines in his spare time was able to drill them out. Just takes "patience and caution." Obviously you do not want to get to that point at all.
I would say no to cutting the heads off as you don't really get any advantage from it.
Old 03-24-2020, 10:16 PM   #7
jack wingard
I would think the advantage is the separation would allow access to the threads to allow penetration of a fluid to the threads and leave enough of the stud exposed to grip and remove.
Old 03-25-2020, 07:08 AM   #8
chrs1961815
Maybe, but the penetrating fluid can penetrate very well. Don't mean to split hairs, I just do not see an advantage. The heat is the main source of success.
Old 03-25-2020, 09:15 AM   #9
Ray in La Mesa
You can heat the bumps around the bolts on the inside of the exhaust manifold, it is more direct heat than the bolt heads.
Ray in La Mesa is offline   Reply With Quote
Old 03-25-2020, 09:22 AM   #10
Joe K
Joe K's Avatar
I have drilled out and threaded several in my experience. Most, in fact.
Best done using the head twisted off and then grind the stub down so it's nearly level with the exhaust manifold surface. This gives you a "true location" for the bolt.
With the extent of the bolt diameter revealed then with a sharp punch "centerpunch" what you feel is the centerline of the broken bolt. Then starting with a 1/16" drill, drill a hole until you feel it "drop" into the void below the broken piece.
Then in 1/16" increments, expand the hole until nearly the root diameter of the thread. IIRC, the bolts are 5/16 which has a root diameter of No. F drill or 0.257. The nearest fractional size is 17/64 which is 0.2656. I would drill this to 1/4" or 0.250 and try to pick out any thread you can reach. Then try for No F drill and pick out more.
If you can get a circle or two of thread clear THEN try putting a 5/16-18 tap and re-tap the hole. More than likely the tap will follow the previous threads removing only what remains of the original bolt. Finish up with a "bottoming" tap which can be made from a ground-off standard plug tap.
If you're a little off-center in your drilling, approaching the final thread root diameter "gently" will help preserve as much as you can of the original female thread. Being off center means you "clip off" one side of the thread form but enough will remain on the other side to allow full bolting. AND clipping off one side CAN make it easier to "pick-out" the remains of the bolt.
Use penetrating oil generously during this process.
In drilling process and coming up perhaps half way to the root diameter, I might try an 'easy out' simply as part of the exercise. I can't for the life of me remember the last time it worked, however. Easy-Outs are a nice marketing name, but don't describe well the heartbreak of breaking one off in the hole.
Hope this helps.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-25-2020, 07:55 PM   #11
jack wingard
Gottem out. Called an old friend the owned an muffle shop. Told me to heat up (very hot) the bolt alone and let it cool down naturally. Do it three times. Came right out. I guess third time's the charm!
