09-26-2019, 11:04 PM | #1 |
Gas additive
Do I need to run some kind Lead/fuel additive in My A ? Is there a certain brand to look for ?
Lefthander1930 |
09-26-2019, 11:15 PM | #2 |
Re: Gas additive
The gas available when Model A's were new or near new did not have lead so it's not needed now.
09-26-2019, 11:38 PM | #3 |
Re: Gas additive
Many add Marvel Mystery Oil to each tank of gas....long history of it being used....4 oz per 10 gallons....
09-27-2019, 12:44 AM | #4 |
Re: Gas additive
I add a lead substiute every fill. 1ml per litre. For thoise not so familiar with the metric system, that's 1 in 1,000. It acts as an upper cylinder lubricant AND a lead replacement. I'm sure there will be something similar available over there. The one I use is Australian formulated and made. (Flashlube)
09-27-2019, 05:45 AM | #5 |
Re: Gas additive
Nothing needed. But a little ATF doesn't hurt.
09-27-2019, 06:57 AM | #6 |
Re: Gas additive
With compression of 4.2:1, I doubt there is anything to worry about. "This didn’t seem to faze Midley, who himself came down with lead poisoning during the planning phase. While recovering in Miami, Midgley wrote to an oil industry engineer that public poisoning was “almost impossible, as no one will repeatedly get their hands covered in gasoline containing lead…”" This has never happened to you, has it .... ? |
09-27-2019, 08:23 AM | #7 |
Re: Gas additive
We have ethynol free gas at our Quick Trip gas stations and some Walmarts here in TX!
09-27-2019, 08:40 AM | #8 |
Re: Gas additive
The model A was made to run some pretty crappy fuel back in that time frame. Tetra ethyl lead wasn't added until higher compression cars became available. All the additives are is a top end lube to increase the life of the valve train. Most modern unleaded fuels already have additive for valves in them. If an engine already has hardened valve seats then a top end lube is really not all that necessary. MMO certainly won't hurt though as long as a person puts in no more than is recommended.
09-27-2019, 12:32 PM | #9 |
Re: Gas additive
Lead additive a waste of money as is ZDDP. Use StaBil or SeaFoam and glug glug glug of MMO or ATF. JMO
Paul in CT |
09-27-2019, 01:35 PM | #10 | |
Re: Gas additive
If no special top oil (f.ex. MMO), then use 0.5% synthetic two-stroke oil. All gear oils burn with a lot of carbon residue!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
09-27-2019, 01:37 PM | #11 |
Re: Gas additive
09-27-2019, 01:55 PM | #12 | |
Re: Gas additive
I guess engines over here did not get that memo. Its worked since it was discovered. Works good on valve guides and keeps carbon loosened up. Also seems to keep carburetors from varnishing. Been using it personally for 6 decades, guess I'll keep on. |
09-27-2019, 06:11 PM | #13 |
Re: Gas additive
Forddan: I never carried a measuring cup with me. Most say 4 oz of MMO to 10 gal
of gas. I just tip the bottle and : glug glug glug. More than 4 oz not going to hurt anything. Paul |
09-27-2019, 08:22 PM | #14 | |
Re: Gas additive
Nice to know from your experience that more than 4 oz will not hurt. As I never wait to have the tank empty it is not easy to add the correct amount. So I was adding "what I though mathematically was correct" but for sure it is more than the 4 oz / 10 G. I only had the car since January. My first year. So still learning. Thanks again!!! |
09-27-2019, 11:52 PM | #15 |
Re: Gas additive
I second that. I've been using ATF in small engines for a long time. Briggs two cylinder engines have a habit of sticking valves. ATF in the gas will solve the issue.
09-28-2019, 05:28 AM | #16 |
Re: Gas additive
At the other end of the spectrum, early hydraulic lifters were famous for sticking/rattling. A cure was an oil drain and a fill with ATF, run the engine until they started working again. Change the oil and give it back to the owner.
09-28-2019, 08:03 AM | #17 |
Re: Gas additive
Posts about gas and oil are always interesting in there results. If it was good enough for Grandpa? OK?
09-28-2019, 08:08 AM | #18 |
Re: Gas additive
Some things change, some don't. Some of the old stuff still works.
