09-26-2019, 04:56 AM | #1 |
Main Bearing Poured Surface
In pouring main bearings I am getting some "pock mark" surface texture. This usually cleans up during line boring. Occasionally I will get a deeper crater...
I am using #2 Babbitt and pouring @950 deg. into a block heated with a propane grass burner torch bringing the block to about 400 deg. Using a Wilson pouring fixture and Mold-Pac as a damming material. Any thoughts, is this normal or should I be looking at something to be corrected? Thanks, Steve |
09-26-2019, 06:43 AM | #2 |
Re: Main Bearing Poured Surface
Sounds like trapped air. I am assuming you are speaking of the casting in the block? While not ideal, if after peening it cleans up, then I would not worry.
09-26-2019, 08:45 AM | #3 |
I have rebabbited a few older machines in my steam and gas engine interests. Usually to the method given by Fine Woodworking Magazine (January-Feb 1983 article by Bob Johnson)
Bob was a restorer for the Smithsonian, did a large portion of the machines of the "1976 Centennial of a Centennial" exhibition in the History & Technology Building of that era and later went into business for himself continuing the tradition of rebuilding antique machinery. He is now passed IIRC. His recommendation was 80% bedding with Babbitt scrapers and bluing. If you get to that point you pretty much have it covered. Line boring/hone/bedding should be considerably better than that. Like a single or two imperfections are probably fine. You can call them "oil pockets." Joe K
Shudda kept the horse. |
09-26-2019, 09:35 AM | #4 |
Thanks, I poured the block main again this morning and all looks fine. Will definitely clean-up in the line bore. Pouring Babbitt for me at least is kind of a Zen thing... Must be well rested and in the good frame of mind. Sort of like my Model A notices cooler weather before I do. Wants a little richer mixture when starting.
Steve |
09-26-2019, 10:26 AM | #5 |
