04-23-2016, 10:44 PM | #21 |
Re: Ohv
Interesting question;
I see 3 markets, in descending order; Touring application, here a 2 port design that uses stock manifolds, limited CR, chamber that can use a stock flat top piston and fair valve spring pressures. Hot Rod application, 4 port design, cross flow, larger valves and medium springs, more CR and still use flat top pistons. Race application, cross flow 4 port design, valve locations moved for optimum valves, race porting, more aggressive CR, chamber and ports refined, Hiperf springs and aggressive rockers. This version should also be a taller design to accommodate the larger ports. Add an oring groove for cyl sealing and solid copper gaskets. The list is actually longer than this. There are a couple very good heads on the market already. The last High-Speed Miller I had here was sn 235. The last couple broken cranks were with 4 port heads, now with my 5 bearing bottom ends, cranks seem to be lasting, transmissions seem to be the next weak link. The issues of alum vs iron for heads is not so much a concern any more. A good quality alum head will be more than adequate if done properly. I see more issues with proper head gaskets and assembly than the heads themselves. Being that Tod has the ability to control most of the costs by doing the work himself could offer a lower cost point. I think the real question is how many could be sold for an offering at $2800? (this price just pulled from thick air) And then what HP levels would be expected? John PS. I have read 735 units produced for one brand, at $4000 ea, that's 2.9 million dollars in transactions. Some how it just doesn't sound reasonable, I could be wrong though.
As Carroll Smith wrote; All Failures are Human in Origin. |
04-24-2016, 01:41 AM | #22 | |
Re: Ohv
Tod |
04-24-2016, 10:50 AM | #23 |
Re: Ohv
p.s. Aftermarket blocks, made after 1934, are not legal for Bonneville racing or F.A.S.T. hill climbs. This doesn't mean it's a bad idea though!
04-24-2016, 11:34 AM | #24 |
Re: Ohv
04-24-2016, 02:07 PM | #25 |
Re: Ohv
Hey johnneilson,
I like your suggestion, regarding the 'O-ring' idea. IMO , many more blown head gaskets could/would be prevented with O-rings around perimeter and 'fire wire' groove between 1#/#2 and #3/#4. However that's done, Tod is making his OHV Head from scratch, so he can do things that were not done originally to improve on an original head...thereby making it more powerful while still being able to bolt it onto an A/B engine , with A/B avail equipment, as originally intended. As Tod is making his OWN version OHV Head, he can incorporate his vision for improvements over the old design and tech ! Namely, larger intake valves and adequate exhaust valves, improved thicknesses and change weak areas that have been exposed over many decades of use. Heck, if he wanted to, he could make a new combustion chamber, maybe better valve cover sealing surfaces and a lot more. Someone said (John Lavoy?) that the OHV Heads are run by guys touring with him. I'd bet that John could help with a survey of his contacts, as to how many would buy/use an OHV Head....if the price could be what they consider reasonable. Is has also been said here that this OHV Head question might be better suited to HAMB ! How so, when these heads were made during and at the same time as As/Bs ? Someone else made comments that a flathead will perform as well/better than an OHV Head...I'd love to see proof of that, eh ! Talk about POWER production of these old OHV Heads, these heads were advertised for and used by truckers due to their power producing performance...over flatheads. Never mind that they cost about $30. a copy, even regular A owners bought and used them. At $3000. a copy today, such equipment would be such a deal. The idea that every OHV Head on the market today is in the $5500. price range, puts it out of reach for most 'frugal' A/B engine owners. Add in shipping/handling and insurance and add me to the frugal crowd also! I have seen many OHV Heads that had to be welded up/fixed up, due to the poor foundry production. There weren't that many made in the first place. So, is it any wonder why replicas in aluminum took over the market place. IMO, when Tod makes blocks/heads for this hobby, either alum or cast iron, at reasonably low price...they will sell. Remember the old truism...if you make it they will come buy it or some such If nothing else, during research of this subject (head making and use of diff metals) I've learned something. Cast iron is NO harder to machine than aluminum, if you know what you're doing and have the right machinery/skill. Last edited by hardtimes; 04-24-2016 at 02:09 PM. Reason: .................. |
04-25-2016, 03:40 AM | #26 |
Re: Ohv
You must do what you want (and no doubt will ) but if it was me, I'd be looking for another point of difference rather than just price. Sorry to bang on about the Riley 4 Port, but I'd bet that a faithful copy in iron would sell well and at a price approaching, if not up to, what the others are charging for their ohv's. Just my 2c but I'm feeling a missed opportunity here Keep up the good work Cheers Juggs |
04-25-2016, 06:04 AM | #27 | |
Re: Ohv
If I had a 4 port to work from, or even pictures, I can make one of those also. And, I am working on changing the Schofield chamber and ports. The one I have has larger exhaust ports than intake. I plan on reversing that. With the molding system I have already, it is very cost effective to run different tooling. Tod |
04-25-2016, 09:16 AM | #28 |
Re: Ohv
Tod, email sent.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
04-25-2016, 09:26 AM | #29 |
Re: Ohv
04-25-2016, 01:37 PM | #30 |
Re: Ohv
I would be interested in a iron Riley head. The others don't interest me. If you have a list put me on it. Thanks Joe
04-26-2016, 11:28 AM | #31 |
Re: Ohv
IMO the best street engine is the 4-port Riley, they produce gobs of torque. They easily clear the firewall, some OHV heads do not, my Cook for instance. They are a little difficult to work on but worth the trouble. Also IMO they are not as good for racing as they put more heat into the block, not too good on B blocks. I have been running them for many years and am still impressed with them! I know where the original patterns are but the owner is still not willing to part with them.
04-26-2016, 04:05 PM | #32 | |
Re: Ohv
Tod |
04-26-2016, 07:53 PM | #33 |
Re: Ohv
Mine are both in use, but will keep you in mind.
04-27-2016, 02:52 AM | #34 |
Re: Ohv
Are there different versions of the 4 Port Mr B? I remember that you thought Charlie Yapp had copied the wrong version of the 2 Port. I've got a copy of the Racing Scrapbook but am away from it right now.
If there are different versions, which is the best? |
04-27-2016, 09:45 AM | #35 |
Re: Ohv
The '33 and '34 heads had larger ports than later ones. All were iron until after the war when Riley made a batch in aluminum, just before he was shut down by the government. Joe Gemsa made one batch then sold the patterns to John Vesco who made quite a few. I don't think either of these guys made any changes in the patterns. They then went to George Butler, he made several minor changes but not any to the ports or chambers.
04-27-2016, 09:49 AM | #36 |
Re: Ohv
Thanks for that
Looking forward to your ohv book by the way |
04-27-2016, 11:05 AM | #37 |
Re: Ohv
04-28-2016, 06:31 AM | #38 | |
Re: Ohv
Didn't Dan Price make some more recently in aluminium? Thanks again for your help |
04-28-2016, 08:01 AM | #39 | |
Re: Ohv
I totally get the mismatch of dissimilar metals, but what else am I missing? Also, I remember finding a website of someone down South who was making OHV conversions out of SBC heads. If I recall, he sectioned them and machined here and there and got some impressive numbers for a kit that cost under $1K. I'll try to find it. Last edited by Tim Ayers; 04-28-2016 at 08:09 AM. |
04-28-2016, 06:19 PM | #40 |
Re: Ohv
No expert here, but I had a 29 ccpu with an iron Cragar head, supposedly an original, whatever that is, and I ran it to Portland from Danville at highway speeds and all the problem I had was with heat in the cab. I had purchased it in Rio Rico, AZ where it gets hot and maybe that is the reason it sold to me in CA. Other than another block of hot iron ahead of the firewall, it sure produced plenty of power and even with a 97 carb I got about 20 mpg overall with o.d. and 600 X 16s. Wish I had it back. It could scoot.
