02-01-2014, 05:22 PM | #1 |
Dipper trough pits
#2 trough has some pitting. Probably will never go thru, but I would like to solder it up. The baffle is practically under it. I'm thinking its soldered on, so how to fill the pits? 95/5 solder, or what? TIA. Chuck
02-01-2014, 06:43 PM | #2 |
Re: Dipper trough pits
If there are no holes, don't worry about it.
02-01-2014, 06:47 PM | #3 |
Ah yes, a little adjustment of the bifocals and now I see the spot welds. Thanks
02-01-2014, 07:33 PM | #4 |
Chuck
why mess with it, I have a lot of good dip trays. just come out and pick one. John |
02-01-2014, 07:39 PM | #5 |
And your first rust through will just add to the small hole 1/8" hole that you drilled to allow the oil to go back to the pan so you get a "complete" oil change?
Well, some do it. Joe K
Shudda kept the horse. |
02-01-2014, 07:57 PM | #6 |
02-02-2014, 01:42 AM | #7 |
But it's a fine point car!
02-02-2014, 04:59 AM | #8 |
Curious, if the trough is empty on startup with the drilled holes, how long does it take to get enough oil in there to feed the bearings ?
02-02-2014, 07:58 AM | #9 |
Thats a question I've had too, never got an answer. I would think there would be a rattle or two and the holes then plugged back up.
02-02-2014, 09:14 AM | #10 | |
Chet |
02-02-2014, 09:22 AM | #11 | |
Chet |
